head problems?
Old Nov 4, 2001 | 12:46 PM
ford86's Avatar
ford86
head problems?
I thought I had a leaking valve cover gasket on my 86 f150 (4.9L). after changing the gasket i discovered that it wasnt were the oil was coming from. When me truck was warm i noticed the oil was leaking around the bolts that hold the head on. The oil was bubbling out of this area.What could cause this? Has anyone had a similar problem? What other damage could this have caused?
Old Nov 4, 2001 | 06:05 PM
bodysaffa's Avatar
bodysaffa
head problems?
I would have a look at the PCV valve. If it is bad it will cause oil to come out somewhere. It may be that the head bolts just look like they are leaking and the valve cover really is.
The PCV valve vents the case, so if it is plugged the pressure has to go somewhere, and it can force out oil with it. On my Rambler it comes out of the dipstick fill tube! Pull the thing out an see what happens. See if it sucks air.
Jay in Reno
Old Nov 4, 2001 | 08:57 PM
ford86's Avatar
ford86
head problems?
The pcv sure was bad.I took it off and let the motor warm up and that seemed to solve the problem. thanks for the help.
Old Nov 4, 2001 | 09:08 PM
royisme's Avatar
royisme
head problems?
wahlturfcare
Nov 7, 2013 02:13 PM
kevind95
43
Jun 25, 2013 08:56 PM
crlrca
Jul 6, 2011 11:15 AM
dirtmonkey11
Feb 14, 2010 02:47 PM
unreng
Feb 15, 2008 10:03 AM
