Sponsored by: Kumho
E-Brake?
Old Feb 23, 2005 | 03:37 PM
wickymustang's Avatar
wickymustang
E-Brake?
I have a 95 F150 2wd 5spd. When I park I put it in gear and then put the emergency/parking brake on. I go to drive it the next time, I take off the parking brake, start the truck but it seems like the emergency brake sticks, til the engine overcomes it. Brakes work great, and when I have my right rear axle shaft replaced I was told my brakes were in great shape, so the shoes and drums are ok. Any ideas as to what to start checking to figure out this problem.
Old Feb 23, 2005 | 08:17 PM
mark a.'s Avatar
mark a.
Probably need a naw e-brake cable.
Old Feb 23, 2005 | 09:55 PM
wickymustang
just the cable from the tensioner thing back or what?
Old Feb 24, 2005 | 08:29 AM
mark a.'s Avatar
mark a.
Probably..I'd get it looked at soon. It's going to wear your brakes down quickly if thats whats happened.
Old Feb 24, 2005 | 10:07 AM
wickymustang
I was told my rear brakes were working fine, nothing wrong with them at all. Including drums/shoes. Anything else it could be?
Old Feb 24, 2005 | 11:42 AM
73Custom's Avatar
73Custom
They may have been working fine, but the ebrake works by applying the rear brakes. So if it sticks, the rear brakes are applied and will be worn down as you drive. About the only way to know for sure is to jack up the rear and try to spin the wheels - if one turns hard, pull the drum and inspect the ebrake.
Marty
Old Feb 24, 2005 | 01:35 PM
wickymustang
This "problem" has been happening since I bought the truck and the shop looked at the breaks 3 weeks ago and said they were fine. No burning smell while driving, it is just like they don't want to release til the engine overcomes them and then they are fine.
Old Feb 24, 2005 | 06:34 PM
mark a.'s Avatar
mark a.
I don't know what else could be causing it. If it was a wheel bearing it would be leaking oil into the drum. I'd tell them to take the cables off and see for sure.
Old Feb 24, 2005 | 07:09 PM
rebocardo's Avatar
rebocardo
The most obvious thing would be a stuck cable. Apply the brakes, coat the exposed parts and ends of the cables with WD-40/PB Blaster and then follow with white grease. Work the pedal up and down a few times and see if the binding goes away.
Old Feb 24, 2005 | 07:48 PM
wickymustang
Next time I can get under there I will do that, should be this weekend hopefully.
