maybe you guys will know
Old Feb 23, 2005 | 03:14 PM
superswamper's Avatar
superswamper
is there a specific fe np435, if so will i have a problem if i use just any old np435 on an fe?
Old Feb 23, 2005 | 07:14 PM
lee's Avatar
lee
Hum,
Good question. If memory serves me there may be a difference in output shaft housing lengths.
Lee
Old Feb 23, 2005 | 11:18 PM
fordeverpower's Avatar
fordeverpower
My second post! My thoughts are the bellhousing needs to be fe specific. The gearbox itself should be fine.
Old Feb 24, 2005 | 02:09 AM
Hypoid's Avatar
Hypoid
I'll second that. Ford was pretty consistent with the shaft pilot and clutch splines. Never hurts to measure.
Old Feb 24, 2005 | 04:28 AM
superswamper
there in lyes the problem, i used the original as a core. then i saw a post or two about different input shafts so i got worried.
Old Feb 24, 2005 | 10:31 AM
Mike G's Avatar
Mike G
My understanding is that the truck bellhousing for an FE is about 1/2-3/4" deeper than a car. Perhaps this is where the input shaft difference arrises. I have my old 4 speed from the 352 sitting out back, want me to measure up something?
--Mike
Old Feb 24, 2005 | 02:01 PM
superswamper
--Mike
if you wouldn't mind. hopefully it the truck housing like you are thinking cause i got a 4x4 case and i'm pretty sure they never came in cars so i'd be alright
Old Feb 25, 2005 | 10:17 AM
Mike G's Avatar
Mike G
See if this helps. The trans was a 65 4-speed model (top mounted shifter), I want to say probably a T18, but don't quote me as I really didn't care what it was (went to a C6).
From flat mounting face of trans to input shaft tip is approximately 6 3/4"
From the end of the snout mounted to the front of the trans to the tip of shaft (exposed splines and input shaft tip) is 2 1/2"
--Mike
