Front end banging
Old Feb 23, 2005 | 02:23 PM
duallydawg's Avatar
duallydawg
Question Front end banging
I have a 02 F350 DRW 2wd 75k and there is a banging noise when I’m driving and hitting bumps on the front driver’s side.
The shocks are new Bilsteins and I thought that one may have been bad and replaced both. Wheel bearings are good and have been repacked. Brakes are good.
I have tried applying the brakes while accelerating and the noise still continues.
Any info would be great.<O></O>
<O></O>
</O>
</PRE>
Old Feb 23, 2005 | 02:38 PM
mech2161's Avatar
mech2161
Sway bar links!
Old Feb 23, 2005 | 02:51 PM
fosterlohr's Avatar
fosterlohr
Sway bar links and Spring Tip Insulators
Old Feb 23, 2005 | 03:14 PM
duallydawg's Avatar
duallydawg
All the bolts and brackets on the sway bar are tight and look good. The tie-rod seems to have alot of movement in it when you rotate it front to rear.
Old Feb 23, 2005 | 03:33 PM
mech2161's Avatar
mech2161
The links may look good, did you pry up and down on the sway bar near the link? The are made just like a tie-rod. I've seen several bad ones.
Old Feb 23, 2005 | 04:34 PM
duallydawg's Avatar
duallydawg
I tried the sway bar in several different locations and near the links. There is no play on either side of the sway bar all looks good. How much play is there suppose to be in the tie-rod and drag link? When I am moving them front to back there is a definite knock when I get to either end on the movement of the arm. How can you tell if it’s the tie-end rods?
Old Feb 25, 2005 | 04:33 PM
duallydawg's Avatar
duallydawg
How much play should there be drag link and tie-rod? Should there be any noise when you move the bar by rotating it front to back?
Old Feb 25, 2005 | 06:22 PM
vancouverpower's Avatar
vancouverpower
ZERO!! You should not have any movement in the rod ends at all.
Old Mar 4, 2005 | 04:40 PM
duallydawg's Avatar
duallydawg
Talking Front end banging
Your never gonna belive this. After many hours under the truck I finally took the truck to the dealership. After an one and half hours and some chassis ears the problem was a loose shock bolt on the REAR!!! The sound was travelling up the frame to the front.
Old Mar 12, 2005 | 05:24 PM
bigal6030's Avatar
bigal6030
I have movement on my drag link (4x2) I can twist it. However, steering is great and no clucking. any advise
al
Old Mar 12, 2005 | 08:07 PM
duallydawg's Avatar
duallydawg
Front end banging
Leave er be.
You can rotate the drag link front to back and you can even get it to bang as you move it front to back. Checked other PSD's and it did this and tested a new drag link on another PSD.
