Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Welding Rookie needs advice
Old Mar 5, 2005 | 10:45 PM
  #31
shaftmountrocker's Avatar
shaftmountrocker
Is that lincoln 225 welder a stick or mig? im looking for a cheap welder.
Old Mar 5, 2005 | 10:59 PM
  #32
hotrod62's Avatar
hotrod62
if you have done elec. work you can do this. Most welders you but for home use run on single phase justlike your dryer does. it is pretty much just fig. out were you want it
Old Mar 6, 2005 | 09:32 AM
  #33
dangaus's Avatar
dangaus
Smile I'm interested
about that used unit, I'm interested, Email me at dgaus at ibms dot bz.
Thanks,
Dan
Old Mar 6, 2005 | 07:09 PM
  #34
mgman's Avatar
mgman
dgaus@ ibms.biz?
Old Mar 6, 2005 | 09:56 PM
  #35
dangaus's Avatar
dangaus
close, the end is dot bz, not .biz.
damn thing wont let me post my email.
Old Mar 7, 2005 | 06:50 AM
  #36
sdetweil's Avatar
sdetweil
If you might be interested in an entry level TIG and Stick machine, here is what I chose. The HF 91811 TIG/Stick welder. Its DC Only (No Aluminum) and 130 amps TIG/ 90 amps Stick. But its adjustable, from 5-130 amps, has a builtin gas valve (gas comes on and off as required automagically), and comes with tig and stick cables.
Scratch start, but because no aluminum, this is no problem.
for $200 it is hard to pass up, you need a gas tank and regulator to use it, everything else comes with. Oh, and a plug end to match your 220 wall outlet. I made a 30ft 10ga extension cord (for another $80), this box only weighs like 15 lbs.
TIG is harder to learn than MIG for sure, but can produce some awesome looking welds.
The next nearest machine, the Econotig from Miller is $1200, and it adjusts only from 30 to 150 amps. The Econotig is also an Inverter machine, so the best are using the same approach.
lots of people on EBAY are (trying and succeeding) suckering buyers on this product, so be careful.
Sam
Old Mar 7, 2005 | 09:14 AM
  #37
66beater's Avatar
66beater
Stick welding is the way to start. its how I learned. My first welder was an $80 Cambel Hausefield from Wallmart. it worked well enough to get the job done.
I now use a Hobart 145 wire fed with GMAW conversion. Hobart is owned by Miller, and the internal parts are the same. I can do far more with wirefed than I could with stick. Thicker stuff sometimes takes multiple passes, but I have better control of the weld.
You can weld sheet with a stick, but its not something you will be able to do right away. Its tricky not to burn through
Old Mar 7, 2005 | 10:53 AM
  #38
83F150Guy's Avatar
83F150Guy
I would have to say to go with a Mig.. it is much easier to use.. to me anyway...I work for a Metal fabrication shop and weld with both Mig and Stick every day.
Once you get the hang of Mig welding you will love it.
Old Mar 7, 2005 | 12:05 PM
  #39
hansen4's Avatar
hansen4
If you take your time and look for a good used welder you might be better off. I found a hobart beta-mig 200 for 500 bucks , I can run differant wire sizes through it. It gives me the best of both worlds.
Old Mar 8, 2005 | 02:53 PM
  #40
33pickup's Avatar
33pickup
220 service
Dan,
If you have an electric cloths dryer you have a panel with 220 already. An electrician can hook you up with another outlet for the welder. You may have to get a higher amps service (like 200 amps). If you need a new service you will probably need a new panel too........more $$$$$$$$$$$$
33 pickup
Old Mar 8, 2005 | 05:16 PM
  #41
xallxforxchristx's Avatar
xallxforxchristx
Say you're interested in welding together a roll cage, exhaust piping, or a bumper, ect on a 4 wheel drive truck...what type of welder would you use to get these jobs done?
Old Mar 8, 2005 | 05:55 PM
  #42
83F150Guy's Avatar
83F150Guy
Stick or Mig will get the job done.. i have used both to build cages.. but still prefer Mig.
Old Mar 8, 2005 | 06:05 PM
  #43
67Pustomp's Avatar
67Pustomp
you can weld sheetmetal with arc welder with small diameter rods. I have welded at 15-25 amps with good results
Old Mar 8, 2005 | 06:56 PM
  #44
chrono4's Avatar
chrono4
well for the exhaust you almost have to use mig, for the rest its all preference. you just have to remember that mig weld strength has to do alot with the prepwork of the work and selecting the right wire and whatnot.
Old Mar 9, 2005 | 01:25 PM
  #45
randylay's Avatar
randylay
Dan, 220 is just adding the other 110 leg that is already supplied in your main panel. So you will end up with 2 hots and a ground. You will need to turn off the electricity up stream, or just be very careful when adding the 220 breaker. The hardest part will be running the wires to where you want the outlet. Hope this helps. Randy
