I've been welding for over 20 years, and here's my opinion. Take it for what it's worth. Buy a 220v AC/DC welder. The extra electrical will be minimal and you can do it youself if you take proper precautions. I personally feel that you will find this welder to be a great all around machine. I own one myself and have for years. I also own a Wirematic 255 (Mig) and a Ranger 250 portable welder, but you can do almost anything you want with a "Cracker Box". Hope it helps.
How difficult is it to put in a 220 service? I've done most types of electrical work, aside from putting in a new panel service. Breakers, runnin wire, outlets, are no problem for me. Do I need some kind of converter to make the 220 happen?
I have an opinion on just about everything and this is no exception. I have been a "welder" for 30 years +/-, and would not trade my Lincoln 220v mig for any machine I have ever used. I find the arc to be a little more stable with the 220 and they also have a longer duty cycle. while you are liquidating cash by a good helmet with the instant dark lens. you will love it . Note: you only have to buy the right stuff once.
All you need to do for electrical is install a 2 pole breaker (probably 50 amp) in your existing panel, proper size wire and correct type of 230v single phase plug. I used mine off the breaker for the cooking range and just paralleled a plug for my welder. It never pulls enough amperage to trip the breaker even when the stove is on (although that is rare around my house since I think my wife is allergic to cooking). Good luck.
I have 4 Lincoln welders, 1-225AC, 1-225AC/DC, 1-130 amp "Mig", and a [20? hp]Gasoline powered 10,000 watt welder-generator. I've been welding 28 years. I would recommend either a Lincoln or Miller 225amp AC/DC stick welder to start with. As others have said, they are the most versatle. If you don't have a torch [or your in a hurry] they are very handy for cutting steel but you'll need a 40 or 50 amp breaker service for the higher settings.
max, if you dont have have two pole power comming to the box then you cant get 220 out of that box. you have to have 220 coming into the box and then you can pull power from there
I would never reccomend stick welding for sheetmetal, as it is pretty difficult. I also don't reccomend that you try to learn on stick welding, if you plan to do primarily mig in your future. I mean...training wheels don't really teach you to ride a bike or people wouldn't fall down when they take them off the bike. Stick welding is usually what people use first, just because it is common.
I have used many welding machines on and off the job, over the last 19 years. For small things, I prefer something like the Hobart Handler line. For larger things, I prefer Miller equipment.
For something that will do it all, but still a relatively low price, check into the Hobart Ironman 210. I was surprised at its abilities. Granted, if it was a company's money, I'd go with Miller, but for money out of my pocket, I'd be fine with the Ironman.
I have an opinion as a welder for 2 days now! I first attempted welding with a stick on two previous occasions many years ago. I sucked, it was hard, the weld was worse than bad, I hated it.
Now that I have to keep my off road 4X4 Bronco II from falling apart, I purchased a Hobart Handler MIG Flux core 125. Man I love that machine! I'm laying recognizable beads after 1/2 lb of wire. I'm having fun, starting an arc is easy (real easy). My machine has a cold tip, until the trigger is pulled, so I place the electrode on the seam, lower my visor, and sha-zam. Did I say I was having fun! I have welded 3/16" plate, butt and angle welds. I spent $350 for the machine and full coverage sheild at TSC, and it is upgradable to gas later. I will leave the drive shafts and heavy stuff to my shop down the road, but for all the light stuff, I'm set.
Dangaus, 220 is already at your house I suspect. Your dryer, if it is electric is 220. But it splits inside the dryer: 110 for the motor and 110 for the heater=220 volts. But, run a separate line for the welder out of the service box with its own breaker. You'll notice a difference in the plug and outlets necessary; slanted terminals for the dryer (20 or 30 amp) and straight ones for the welder (50 amp). But, you'll still get the power takeoff from the same service box. A decent residential electrical how-to book will show the way. As always, before you pick up a tool, pick up a book. I did my garage for 60 amp 220V and I'm as simpleton as it comes. I own three books on electrical---I'm that careful.
