Fuel line
Old Nov 5, 2001 | 08:09 PM
cbwarrior's Avatar
cbwarrior
Fuel line
Old Nov 8, 2001 | 06:53 PM
ragingbull's Avatar
ragingbull
Fuel line
I am presently replacing a 302 which has a 1/4 inch fuel line.
The replacement engine is a 460 which I will run a 3/8 fuel line.
My question is :
On the rear main tank,can I connect 3/8 to the main unit or do I have to replace the fuel sending unit to a 3/8 connection.
The conversion is going into a 1980 standard cab custom 1/2 ton.
Thanks
Old Nov 8, 2001 | 07:00 PM
Franklin2's Avatar
Franklin2
Fuel line
Check the parts store or the Ford dealer on part numbers for the 302 unit and the 460 unit. You will have to go up a couple of years for the 460 since I don't think it was offered in 1980. If the part numbers are different, I would change it. Try to follow what the factory did for less trouble down the road.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
