1983 Ford Explorer
Old Nov 7, 2001 | 09:20 PM
hightpockets's Avatar
hightpockets
1983 Ford Explorer
1983 Explorer is the 351M a 400 block or the small block
the anti freeze on my daughters truck went into trhe oil.
I have a 351w . I was wondering if that would fit in it.
Old Nov 8, 2001 | 07:38 AM
slikness's Avatar
slikness
1983 Ford Explorer
The only problem would be the bell housings on the transmissions are different on the 351M and 351W, so...you would have to swap trannies also.
'82 F150 2WD w/351W (orig 300 I6)
Slik
Old Nov 8, 2001 | 07:15 PM
Franklin2's Avatar
Franklin2
1983 Ford Explorer
I would double check to make sure she has a 351m. This was the year I thought they did away with that engine, or maybe it's a transition year. Ask her to count how many bolts hold the valve cover on. 351m would be 8 bolts, 351w would be 6 bolts.
Old Nov 8, 2001 | 08:58 PM
fishmanndotcom's Avatar
fishmanndotcom
1983 Ford Explorer
nuknuk
Sep 8, 2016 05:37 PM
Amp.n.dewh
Jun 6, 2016 06:14 PM
CCXVI
Mar 24, 2016 06:16 PM
dvideo22
Bronco II
Dec 1, 2015 05:38 AM
Hig
Jul 23, 2015 01:35 PM
