cowl hood
Old Feb 22, 2005 | 09:12 PM
hotrodfordkid's Avatar
hotrodfordkid
cowl hood
does any one know of a company that makes cowl hoods for the 73 ford trucks if not does any have any tips on doing it yourself thanks
Old Feb 22, 2005 | 09:19 PM
460 Crew's Avatar
460 Crew
Only hood options I found for the 73-79 or the 67-72's were on www.USbody.com. with their GT hood and clip. Problem is they only sell the clip as one piece and not just a hood and they don't have a cowl one either. I belive they have cowl add-ons that you can add to your stock hood.
Old Feb 22, 2005 | 09:57 PM
Gregg C.'s Avatar
Gregg C.
Try JC Whitney. They list afew that Lund makes.
Old Feb 22, 2005 | 10:23 PM
Flatbed392's Avatar
Flatbed392
USBody.com has a cowl hood for either pins or you can get one that will use the latch and everything off of your stock hood.
Don
Old Feb 22, 2005 | 10:56 PM
jstandle's Avatar
jstandle
If you were handy you could cut your hood, one slice on each side, raise it up a bit and weld in some pie peices. I've seen them done that way.
I've got an ABS cowl ind. scoop from JC Whitney on my Cherokee and it's a POS. I have it riveted down and it's busting/cracking all apart from closing the hood.
I've got a fiberglass remake Mopar S/S scoop on my '65 Coronet, it was riveted on then glassed and smoothed down to look as part of the hood. So far that one has held up just fine, but it hasn't gone through the abuse my Cherokee has.
Jordan
Old Feb 22, 2005 | 11:43 PM
FordPickup460's Avatar
FordPickup460
Summit sells a few Harwood brand cowls that go on top of your original hood.
Old Feb 23, 2005 | 01:41 AM
ivanribic's Avatar
ivanribic
Here's mine which is very similar to the Harwood scoops. It's glassed in, but still waiting on paint (as always ). Scoop cost me $90 I think, and then the fiberglass and some time is about it.
https://www.ford-trucks.com/user_gal.../59324.520.390
Old Feb 23, 2005 | 10:34 PM
76hi-boy's Avatar
76hi-boy
look up extreme 4x4 works on the computer and email him. he can get you a 4" cowl induction hood for about 500.00 it looks really nice.
Old Feb 24, 2005 | 12:30 AM
Phinxter's Avatar
Phinxter
Wow guys way to put a Chevy design on your Ford. How about a teardrop hood that would be kinda cool
Old Feb 24, 2005 | 01:33 AM
FordPickup460
Ivan, where did you get that cowl, and how hard was it to put on ? Im thinking about that for my 77 when its done (again).
Old Feb 24, 2005 | 09:19 AM
KJKozak2's Avatar
KJKozak2
I made my own out of sheet metal. It's pretty easy. Cut out the top and sides, weld 'em together, sand it all down and mount 'er up. There's a few pix in my gallery under 'justpix'.
Kevin K.
Old Feb 24, 2005 | 09:32 AM
73Custom's Avatar
73Custom
I agree, I'm tired of cowl induction - leave it for the camaros and chevelles. I want a '69 Mach 1 scoop on my '73 F100. But I have no hood clearance issues (which a cowl is good for), I just want a meaner look. But that's just my opinion.
Marty
Old Feb 24, 2005 | 09:34 AM
76hi-boy's Avatar
76hi-boy
i put a 1970 amc rebel machine hood scoop on my 79. but i sold it.
Old Feb 24, 2005 | 09:51 AM
KJKozak2's Avatar
KJKozak2
The cowl I have is 90% function and 10% looks.
When we go off-roading, we run through several deep water holes, and I've had too many situations where water makes it into the carb and leaves me dead in several feet of water. Forward facing scoops on the trails also tend to suck water/dirt in some instances.
Since I put the cowl on, I've never had any water/dust/dirt/ problems on the trails. I've also driven this in wicked downpours at 55 mph without a problem.
On a street machine that never sees rain, I could see a nice old stang scoop. They DO look pretty mean.
Kevin K.
Old Feb 24, 2005 | 09:59 AM
76hi-boy's Avatar
76hi-boy
how is cowl induction a chevy design?
