Sponsored by: Kumho
Major Vibration...
Old Feb 22, 2005 | 09:02 PM
90F1505.0L's Avatar
90F1505.0L
Question Major Vibration...
I have this real bad vibration when I am going about 35 mph. Well that is not it, also I took it out on the interstate and there is allot of road noise and basically vibration at all speed especially around 35 mph. I just recently took it in to get an alignment done on it and they my tie rod was bent causing my truck to pull to the right really bad. Well the genius that I am decided to go home and swap the left and the right front tires. I did that and it doesn't pull to the right no more but the steering wheel is off center to the right a little. So what I am thinking is right front is trying to compensate for the bent tie rod and worn(outer) left front tire and causing all this vibration. Because it never vibrated once until I did the front tire swap. I apologize for the long story. Any suggestions? Honestly I was going to take it in and have them rotate and balance the tires. Maybe that might help.....?
Old Feb 23, 2005 | 11:49 AM
73Custom's Avatar
73Custom
Having the tires rebalanced is a good place to start.
Marty
Crazy4x4
2004 - 2008 F150
Sep 16, 2014 09:16 AM
pmasley
Nov 10, 2010 09:42 PM
wesayso
General Automotive Discussion
Nov 24, 2005 07:14 PM
2Northstars
1997 - 2003 F150
Jan 22, 2005 07:22 AM
