overheating
Old Feb 22, 2005 | 06:21 PM
gonzales7727's Avatar
gonzales7727
Angry overheating
hey fellas,
was on the way home on the freeway in my 86 f150 302 fi, when all of the sudden i hear this wierd noise coming from the hood, i look down at the gauges and i am overheating big time.
i pull over and steam is coming from under the hood, i pop the hood and there steam everywhere andwater shooting everywhere coming from the resevore and the resevore is boiling and overflowing.
since i had no water i had no choice to have it towed home.
what do you fellas think?
also, about 2 weeks ago i changed the water pump and the thermastat.
Old Feb 22, 2005 | 07:16 PM
mstarr's Avatar
mstarr
I would guess bad thermostat. Start it up and let it run till it starts getting hot, then squeeze the radiator hose. If it is still real hard, then the thermostat isn't opening. Or just take out the thermostat and see if that fixes the over heat problem, if it does then put a new one in.
Old Feb 22, 2005 | 07:21 PM
Beast12's Avatar
Beast12
Maybe you put the thermostat in backwards? Or did you get a waterpump that pumps the opposite of what you need?
-Matt
Old Feb 22, 2005 | 07:57 PM
gonzales7727
well the thermastat is working because it run kind of on the warm side anyways and when it would get to about were it gonna start running hot, it would all of a sudden jump back down below 190 deg, also what do you mean about the water pump not doing what i wanted it to do.
Old Feb 22, 2005 | 08:05 PM
Beast12's Avatar
Beast12
I know for some engines you can get reverse flow water pumps. I am not sure if there is one for this engine in this year.
But, you said the temp gauge level went up then back down. I would start the truck up when COLD and take off the rad cap. See if after a while the engine coolant is circulating around. If it is then the water pump is fine.
Another thing could be your fan clutch. If it is screwed up then it won't work when your engine gets hot and pull in cooler air. Also, is your fan shroud in place?
-Matt
Old Feb 22, 2005 | 08:12 PM
gonzales7727
i think i was a little low on water, do u think that might be the problem?
Old Feb 22, 2005 | 08:17 PM
dave74-360bb's Avatar
dave74-360bb
if this was the first good run you gave the truck you may have had an air lock in the cooling system
Old Feb 22, 2005 | 08:22 PM
Beast12's Avatar
Beast12
How low on water? A cooling system take around 12-18 quarts of coolant. I would top it up then see how it does. Just keep an eye on the gauge.
-Matt
Old Feb 22, 2005 | 08:23 PM
gonzales7727
no, i been driving it for about 2.5 weeks now.
Old Feb 23, 2005 | 08:01 AM
ktp's Avatar
ktp
make sure your rad. cap is holding specified pressure, if not your water will boil at a lower temp.
Old Mar 15, 2005 | 06:24 PM
gonzales7727
ok guys, been messing with the truck latley and i still can't figure it out.
Filled up with water and started it up, shoved my finger in the rad to see if it was flowing, i can feel that it is. kept it running for about 6-8 more mins and i was about to shut it off and all of a sudden i see water flowing out of the resavore, i felt the rad hose to see if it was tight and it felt like it was open so i have no idea what the hell is wrong.
anymore suggestions would help!!!!!!!
Old Mar 15, 2005 | 06:35 PM
gonzales7727
also i got a pressurized cap about 3 months ago
Old Mar 15, 2005 | 09:00 PM
mstarr's Avatar
mstarr
Well, lets go all the way back to the beginning. When did this start? What was the original reason for changing the water pump and thermostat?
And how much is coming out of the radiator? You system will normally push out a little coolant when it gets hot because of expansion. Then it should draw it back in as it cools. If your coolant reservoir is overfilled or mounted at a wierd angle, it will overflow even thought there is nothing wrong.
Old Mar 16, 2005 | 04:48 AM
ktp's Avatar
ktp
Is the rad. original? Have it flow checked, if it is plugged with corrsion it will never cool properly. It may take a recore or replacement to correct. They can get so bad that aftermarket flushes will not work. Allow your engine to get warm then put your hand flat on the cooling fins feeling for cool spots where the water cannot flow because it is plugged. If you find such spots, replace the rad.
Old Mar 16, 2005 | 04:52 AM
ktp's Avatar
ktp
Also look for a continous flow bubbles in the fluid which could indicate a leaking head gasket. This will put lots of heat in a cooling system.
srqdiesel chef
Jun 18, 2014 09:38 PM
sensibull
Jun 14, 2014 07:59 PM
watsonj8
Sep 17, 2011 06:32 AM
walt590
Jun 29, 2011 10:45 AM
bamaboy
Jul 3, 2005 08:55 PM
