05 SD Which Limited Slip??
Old Feb 22, 2005 | 03:07 PM
photonv's Avatar
photonv
Question 05 SD Which Limited Slip??
I have an 05 F250 SRW Superduty truck. CCab long bed. 4x4. It came with an open diff. I would like to add a limited slip. I am in the desert and deal with a lot of sand. Can someone tell me what axles I have and any experience with different LS units on or off road.
Old Feb 23, 2005 | 12:05 AM
SoCalDesertRider's Avatar
SoCalDesertRider
Front axle: Dana 60 high-pinion (reverse-cut gears).
Rear axle: Ford 10.50" full-float, made by Visteon.
My truck, though older, is similar to yours: '92 F350 SRW CrewCab 4x4 longbed. I also use my truck in sand in the California desert, as well as for hauling a camper and pullling a trailer with dirt bikes for weekend fun. Mine came originally with regular open differentials front and rear. The truck's off-road traction was rather embarassing, even with good tires (BFG AT's) and dropping the air pressure.
I opted to put a Powertrax Lock Right auto-locking differential in the rear axle and am quite happy with it. It's a completely different truck off-road now. The truck will go alot of places in 2wd now that previously required 4wd and when I put it in 4wd, it claws it's way through pretty much wherever I want to go with it .
The Lock Right differential is a locker (like a Detroit Locker), which may or may not be something you will like. Lockers make a little clicking and clunking noise and chirp tires when you get on the gas. You can find out more about it by checking out the manufacturer website: www.powertrax.com.
jmccracken1214
Nov 27, 2016 04:08 PM
blloyd29
Mar 28, 2016 07:11 PM
Curt's05
Aug 11, 2011 01:23 AM
charlierogers
Sep 30, 2008 08:31 PM
jasonlasvegas
Sep 13, 2004 05:31 PM
