Sponsored by: Auxito
99' 150 fuel filter location
Old Feb 22, 2005 | 01:54 PM
haten'chevs's Avatar
haten'chevs
Ok, I did a search and found out HOW to change my fuel filter BUT wheres it at? 99' F150 4x4 off road 5.4, auto.
Thanks
Old Feb 22, 2005 | 03:18 PM
ruffed grouse's Avatar
ruffed grouse
The fuel filter sits directly underneath the drivers side door on the frame rail. Look hard enough and you will eventually see it. I just attempted to change the fuel filter out on my 99', it did not go as planned. I could not get enough leverage to get the fuel filter off. I suggest using the steel scissor type device rather than the plastic tools.
Old Feb 22, 2005 | 03:49 PM
haten'chevs
Thanks. I already bought the metal tool so I should be Ok there. How did you bleed your pressure off? I was gonna try the "wreck" switch and then crank it a few times.
Old Feb 22, 2005 | 03:58 PM
markgilmore1322's Avatar
markgilmore1322
Yeah, disconnecting the inertia switch and cranking it has worked fine for me.
Old Feb 22, 2005 | 04:46 PM
ruffed grouse
Several methods are believed to work. The inertia switch shutoff, open/take off gas cap, take out the fuel pump fuse and turn the motor over until the truck dies. There is also a bleeder, like a tire valve near the fuel filter. Hey...let me know how the job goes.
Old Feb 24, 2005 | 09:15 AM
haten'chevs
Well I changed the fuel filter last night. Went easier then expected. I have the metal tool and I see why the plastic one wont work. I pulled the fuel pump fuse and cranked it. (5th fuse up on right side of fuse panel under hood , 20 amper). Just flip up the locking taps, slide the tool in there and push back (I pulled on the hose slightly at same time) off comes the hose (out dripples some gas down my arm) unclipped the filter, clipped the new one in, hooked hoses back up and away it went.
scrappy2686
1997 - 2003 F150
Jan 26, 2013 08:40 PM
23mightymouse
1997 - 2003 F150
Jan 4, 2010 08:35 PM
Just for Me
1997 - 2003 F150
Oct 20, 2009 06:09 PM
ARCHITECT61
1997 - 2003 F150
Oct 25, 2005 01:12 PM
GEllsworth
1997 - 2003 F150
Jul 4, 2003 02:50 PM
