Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Wall Coverings
Old Feb 22, 2005 | 01:54 PM
trihope's Avatar
trihope
Wall Coverings
Does anyone have any ideas for a wall / ceiling covering for garages? Right now I have a waferboard wall covering and just open joists and insulation on the ceiling. I would like to get something like a finished paneling, maybe be plastic laminate, without looking too tacky.
I could go the drywall route but I was looking for something different and that could be done quickly. Any suggestions?
Thanks
Old Feb 22, 2005 | 02:14 PM
460f250's Avatar
460f250
Whatever it is keep it light colored and easily scrubbable. Be nice to be able to attach stuff to it as well, that's something you can't easily do to paneling.
Old Feb 22, 2005 | 02:28 PM
Big Dave's Avatar
Big Dave
1/4" pegboard, painted white. It holds in insulation, and gives lots of opportinuties for storage.
Old Feb 22, 2005 | 02:38 PM
Rosati's Avatar
Rosati
You can also use FRP (Fiberglass reinforced panels) over existing drywall. This material is readily available at home centers (Lowes, Home Depot).
It is generally used in bathrooms and kitchens and is available textures and smooth. these easily clean up with hand cleaner or soft scrub.
You glue it on the wall with liquid nails or contact cement and the joints use an extruded vinyl that slip over the edges to smooth the seams and corners.
It cuts fairly easy with a fine toothed saw blade and can be trimmed with a pair of avaitor snips.
Old Feb 22, 2005 | 03:08 PM
mleichtle's Avatar
mleichtle
That FRP can be nailed on to. The nails have plastic grommit thing. Look in any truck stop restroom.
Old Feb 24, 2005 | 09:26 AM
Rosati's Avatar
Rosati
I've used the nials before as well. But they just look 'southern engineered' and get in the way of cleaning the panels. When I genereally do a job, I used contact cement because it can be rolled onto both panels, let dry, then pressed in place. It leaves a nice smooth surface that wont be hard to clean.
Old Feb 24, 2005 | 10:13 AM
Torque1st's Avatar
Torque1st
Posting Legend
What is the fire resistance rating of FRP with and without a sheetrock backing? Do you use 1/2" or 5/8" sheetrock backing for a fire barrier with FRP? I assume that when you use adhesive the FRP is going up over sheetrock. Can the FRP be used alone without some sort of backing material?
muscletruck7379
Garage & Workshop
Jan 27, 2014 01:14 AM
actioncam1
Garage & Workshop
31
Jan 2, 2007 06:32 AM
vancouverpower
25
Dec 1, 2005 09:26 AM
Hairy Dog
Garage & Workshop
31
Nov 2, 2005 09:01 AM
bencbr
Garage & Workshop
21
Dec 14, 2004 12:06 PM
