Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Shop wall coverings
Old Nov 19, 2006 | 12:08 AM
actioncam1's Avatar
actioncam1
Shop wall coverings
Just started a new shop (21x42 attached garage, 3/4 12' ceilings, remaining 8' ceiling w/ loft) and I am looking for options to cover the walls. I like the look of drywall and will be using it for the ceilings and the walls. I would like to find something to cover the bottom 4 feet or so of the wall that is more durable than drywall and a little more water resistant (the shop has a floor drain and I will be washing vehicles inside during the winter). My first thought was to buy 4x8 sheets of waterproof paneling (the kind you see in inexpensive shower stalls), but I'm not sure if that material is tough enough to hold up to the occasional door ding or slipped wrench. Any thoughts would be helpful.
Thanks
actioncam1
Old Nov 19, 2006 | 12:29 AM
FirstTry's Avatar
FirstTry
what about finding a nicer grade plywood. a fellow farmer got a great deal on a bunch of plywood that was finishing grade.ummmm it was a real ligth wood with dark streaks in it. real nice stiff. but anyway, he lined his entire shop with it. if you got a nice grade and did soem sort of sealer on it i dont see why it wouldnt do what you are asking. the shower stuff i am thinking of is would do nice as well, but the stuff we used was ridiculous expensive. i might be thinking of something diffrent though.
Old Nov 19, 2006 | 06:36 AM
Torque1st's Avatar
Torque1st
Posting Legend
Regular OSB is cheap and if sealed with some polyurethane it should work OK. OSB would also work for the upper walls and would be much stronger and more durable than sheetrock. You would need 5/8" sheetrock on any wall that is common with a dwelling for fire resistance.
Old Nov 19, 2006 | 07:21 AM
frederic's Avatar
frederic
outdoor plywood which you slather polyurethane on both faces, the bottom, and the sides.
Polyurethane like for hardwood flooring. Two coats on the faces and three on the edges will prevent any water from dissolving the wood.
Old Nov 19, 2006 | 04:42 PM
havi's Avatar
havi
I'll have the Roast Duck
I personally used 7/16" OSB top to bottom, with 1/16" melamine paneling(pioneer white) over that. I did the math, and at the time it was cheaper than buying paint, sealer, brushes, rollers, etc.... I know a friend who used steel panel("durapanel") to line his weld shop, which was prepainted white. A little expensive, but sure fireproof. My 2 cents.
Old Nov 19, 2006 | 05:05 PM
fordpick-up's Avatar
fordpick-up
I used drywall in my shop but you have to be careful or you will be knocking a hole through it. I am going to put either osb board or plywood exterior grade all around the bottom to prevent any damage. Good Luck
Old Nov 19, 2006 | 05:31 PM
mlb4966's Avatar
mlb4966
Drywall the entire shop then cover the bottom 4' with FRP lying horizontal.
FRP is Fiberblass Reinforced Panel. This is the paneling that is required usually by DEC for foodservice locations and wetrooms. Dont be shocked by the price of the paneling and the adhesive. Great for wet locations and easy to clean.
Old Nov 19, 2006 | 05:57 PM
alchymist's Avatar
alchymist
"Mifflin Clay"
You can always use pressure treated plywood for the 1st 4 foot. If you're going to do welding, cover with galvanized sheet metal where needed.
Old Nov 19, 2006 | 07:21 PM
rebocardo's Avatar
rebocardo
Put on the drywall, then screw 2x2 pressure treated to the bottom of the wall over the drywall and back it liberally on the floor and wall with silicon RTV. Then rest 1/8" polycarbonate on top of this (which comes in 4x8 sheets and is flame retardant) and screw it to the wall into the 2x4 studs. The 2x2 will prevent water from migrating under the wall to the 2x4 wall and rotting it out. Seal all edges with clear GEII silicon. You can run a clear bead before putting on the poly 4x8 panel and let it rest in the bead.
then screw 1/8" thick polycarbonate (4x8 sheets) on the bottom
Old Nov 19, 2006 | 08:48 PM
dffay's Avatar
dffay
When it is all done, don't forget tastefully accesorized poster art. Beautiful XX chromosone types with lots of upper body confidence.
Every man needs at least one in the shop. The poster I mean.
Old Nov 19, 2006 | 10:43 PM
Torque1st's Avatar
Torque1st
Posting Legend
Galvanized or painted "barn metal" would certainly be durable, waterproof, washable, fire resistant, and resist welding sparks...
Old Nov 19, 2006 | 11:57 PM
actioncam1's Avatar
actioncam1
Thanks for all the input. I went to local HD today and found a material called "tile Board" It is water proof, guaranteed not to chip and only $12 for a 4'x8' sheet. I am also going to look into the "fiberglass reinforced panels". What ever I do use I want to use a white color to keep the shop bright, but I think I will cover a spot for welding with galvinized metal
Thanks again
actioncam1
Old Nov 20, 2006 | 01:52 AM
Torque1st's Avatar
Torque1st
Posting Legend
Have an item number for that stuff? The HD (and Lowes) website are damn near impossible to find anything on, worse even than walking into a store and asking an employee.
Old Nov 20, 2006 | 11:58 AM
tewferford's Avatar
tewferford
Its in the paneling section. I think it is only 3/16 thick tho.
Old Nov 20, 2006 | 10:48 PM
73f350sc's Avatar
73f350sc
Drywall all the way down then use some liquid nails to put up the tile board, on top of the drywall, should hold up pretty well.
-Chris
