what years are interchangeable
Old Nov 13, 2001 | 10:19 PM
quads's Avatar
quads
I have a oppertunity to buy a 1973 F100 for $100 witha good C6 transmission does anyone know if it is interchangle into a 1982 F100 with a 302 AOD?
Thank You and Godbless
Old Nov 13, 2001 | 10:54 PM
Franklin2's Avatar
Franklin2
What motor does the f100 have or had?
Old Nov 14, 2001 | 08:30 PM
quads's Avatar
quads
both are 302's
Old Nov 15, 2001 | 11:47 AM
jwtaylor's Avatar
jwtaylor
[updated:LAST EDITED ON 15-Nov-01 AT 12:48 PM (EST)]If it's bolted to a 302 then it will fit your 302 as the bolt patterns are the same. My only concern would be the kick down on the carb but I don't think that should be much of a concern. At least I think that is the case. Good luck, sounds like a pretty good deal
Old Nov 17, 2001 | 10:34 AM
jeff967's Avatar
jeff967
The motor and trans out of the '73 will fit. Are you planning a complete swap? If so the only issues you may run into would be the oil dipstick is in the timing cover instead of the drivers side and your drive shaft may not be the correct size. If you are going to reuse your old tranny then I would make sure the flywheel on the '73 fits the AOD and use the intake & carb off your current engine so the throttle and kickdown cables fit.
Good luck,
Jeff
Old Nov 17, 2001 | 10:34 PM
bodysaffa's Avatar
bodysaffa
Post what years are interchangeable
64f100sixcylinder
Feb 11, 2014 12:39 PM
jlang
Jul 13, 2009 12:12 AM
82F100SWB
Jul 27, 2002 06:25 PM
rogerf100
Mar 20, 2002 08:17 PM
fatforty
Nov 11, 2001 08:45 AM
