Tow question
Is it safe to tow this with the Overdrive "On"? The tongue weight is about 120 lbs.
I have a 2001 F250 5.4
Thanks all!
I almost can't feel the utility trailer and don't even think about the tranny.
One word of warning on these utility trailers, maybe two words...
The tires these trailers use are absolute crud. Very low weight rating about 500-600# I think. If you overload even a little, you Will get a blowout. I have had two blowouts with both original cheesy tires. It is way too easy to overload these trailers. A scoop of compost will do it, even half a scoop will do it if you get some rain. First chance you get, go out and buy some tires with a better rating I have Green Ball with a 950 rating. I think all the tires are made in China, but so far the Greenballs have worked good for me, even overloaded.
These trailers in general seem to rust pretty easy, especially the lights, so check the running lights every once in awhile and clean up or protect the connections. Also dogs love the exposed wiring, so if you have a dog, don't worry about the connections, they are already gone.
Good Luck,
Jim Henderson
Jim,
This is a homemade trailer that I built using an old F100 front end, so it actually has full size tires on it already. This thing is built like a tank. I don't think I will have any problems with it. As for the dog........... I built in a little saftey box for the wires that the mutt can't get into. Thank you for all the info!
Tim
