hard starting and rough running
Old Feb 21, 2005 | 08:09 PM
sourpuss's Avatar
sourpuss
89 ford diesal just the other day got real hard to start have to hold peddle down to keep running and idles real rough and i have changed fuel filter what else can i do
Old Feb 21, 2005 | 09:10 PM
rancherman84's Avatar
rancherman84
sounds like a maybe an air leak?do you have dual tanks? if so try switching to the other one to try to eliminate some stuff.
Old Feb 21, 2005 | 09:24 PM
PLC7.3's Avatar
PLC7.3
Check the fuel pressure from the lift pump.
Do pressure and flow test on the fuel at the Schrader valve on the filter(FSS- fuel shutoff switch disconnected). Remove the tire valve core and hook a hose and pressure guage on it should see 4-6 psi when cranking. Then do a fuel quantity test same place, should see 1/3 pint in 10 seconds of engine cranking, route fuel to a suitable container with a hose.
If there is a problem with the lift pump and you are changing it, ensure the new pump comes with instructions as to correct installation proceedure if it is the newer model pump with the almost straight arm.
Old Feb 22, 2005 | 08:37 AM
sourpuss's Avatar
sourpuss
thanks plc7.3 but if its the lift pump would it run good on the highway and lots of power
Old Feb 22, 2005 | 11:46 PM
PLC7.3's Avatar
PLC7.3
I will say possibly.........if the L pump will not pump enough at cranking speed it may at hyway speed when it is running. The Lpump normally has a pressure of 4-6 psi, but the IP only needs 2 psi to operate with the right quantity.......fuzzy area for sure.
I guess that is why someone set those specs for a good Lpump test......at cranking speed. Gotta get it started first.........
