Behind the intake elbow....follow the PCV hose from the passenger valve cover and you should see it.
I found it and am going to replace it while I got it off,I have spent way too much time with the missing at 35 to 50 mph problem.
I changed all plugs and coils,fuel filter,air filter.
I am probbaly going to change the IAC also,it looks fairly easy to get to.
Thank You
Which engine is what,I no one's gas what's the other. 5.4L 330cid V8 BI-FUEL FI (Z)
The hard part is getting the damn plug off then back on again. Also the new ones usually don't come with a gasket so either take good care of the old one or make sure you get one with the new IAC.
