How to replace floor mat retaining hook?
Old Feb 21, 2005 | 04:49 PM
Whilly's Avatar
Whilly
I don't know if this is even worth it, but does anyone know if its possible to replace the driver's side retaining hook for the floor mats of a 98 Expy.
I don't think I even need the hook with the stock mats as they grip the carpet pretty well. But I got these catchAll mats, and without that hook, the driver's side mat kinda slide around. So, does anyone know how to replace it?
Thanks,
Steve
Old Feb 26, 2005 | 05:05 PM
78Explorer's Avatar
78Explorer
If you're talking about REMOVING it...it should just back out like a screw - turning it counter-clockwise. As for WHERE to find a replacement, other than Ford, I'm not sure where you'd get one.
Old Mar 22, 2005 | 06:04 PM
Whilly's Avatar
Whilly
Thanks Elder,
Sorry for not getting back to you earlier. I figured out how to remove it. Its a clip that wraps around two slits in the carpet and then locks closed. I guess I have to order one from Ford. Thanks for your reply.
Steve
Old Mar 22, 2005 | 07:32 PM
lakesidebluexpy's Avatar
lakesidebluexpy
gosh, won't a "stealership" likely want an arm and a leg for this? why not look for one in a wreck yard? likely donor candidates would be f-150's, navigators in addition to expy's. if it comes out that easily.....?????
Old Mar 22, 2005 | 09:01 PM
Whilly's Avatar
Whilly
lakeside, the 'stealer' would probably charge an arm and a leg for it. Only thing is I mangles up the other one while trying to take it out, don't know if I might not do it again, but it might be worth a shot. I guess I'll try to make some calls tomorrow.
Thanks,
Steve
RRRAVEN
Jun 19, 2021 10:23 PM
Gembone
Dec 2, 2014 03:02 PM
Pitt4212
6.7L Power Stroke Diesel
34
Jun 14, 2012 10:47 AM
fran m
Oct 1, 2005 09:37 PM
