crane compucam upgrade
Old Feb 21, 2005 | 03:48 PM
bob1987f's Avatar
bob1987f
hello, im the guy putting an 88 mustang roller 5.0 into an 87 f-150 non roller 5.0.
ive been told not to use the stock mustang cam in a truck cause its for high rpm horses....so i just got a crane powermax 2020 cam (formerly compucam) and i was wondering if anyone else is running this in a truck and how it performs.
the specs are .530 .530 lift, 262 270 duration and 112 degree lobe....oh im doing a mass air conversion too with an 89 mustang computer so it wont mess up the speed density system. ive got a cold air intake and headers for it......thanks for any info! (aod with stock rear)
Old Mar 9, 2005 | 07:13 AM
Mecheng's Avatar
Mecheng
I'm thinking about doing the same thing but with a milder Crane cam, 364211. Its keeps the old firing order too. That's what Crane recommnded to use with the stock EFI truck set up. I am transplanting a 91 Cougar H0 into my 85 F-150.
Now do you have to get new roller lifters when swapping cams?
Old Mar 9, 2005 | 09:35 AM
Blurry94's Avatar
Blurry94
The Mustang roller does lack a little down low, but makes up for it in mid and high rpms. One thing you may want to look into is to see if you have to use a steel dist. gear with that cam. I think the factory gears are broonze and a roller cam (that requires a steel dist. gear) will chew it up and send the particles into your oil system.
Old Mar 10, 2005 | 08:31 AM
bob1987f's Avatar
bob1987f
but what if the motor came with a factory roller cam? should i still worry about the dist. gear? thanks........
Mecheng........if your block already has roller lifters....just inspect them and if they are in good shape you can reuse them.
Old Mar 10, 2005 | 10:29 AM
baddad457's Avatar
baddad457
If your motor had a roller cam to start with , it's got a steel dist gear. Ford NEVER used bronze gears on production engines. Flat tappet motors had cast iron dist gears and have to be changed to steel for a roller cam.
Dlasure2
15
Sep 9, 2015 11:23 AM
Tenderpaw
Jul 14, 2009 03:29 PM
epos48
30
Feb 12, 2007 07:14 PM
42nineranger
Nov 27, 2006 06:14 PM
Rumproast
Jun 27, 2006 01:40 PM
