I recently purchased an 02 Explorer Limited sans working heated seats. The stealership says both heating elements are bad and are asking $750 each to replace the front seats. The light does not come on when the button is pressed which makes me hopeful it is just a fuse however, visually they look fine although I cannot locate which fuse to pull from the owner's manual. Any ideas?
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
