cam walking
Old Feb 20, 2005 | 11:48 PM
mattri's Avatar
mattri
cam walking
Has anyone had problems with this, or heard anything about it? There's a post on fordsix about it but I've never heard of a 300 having a problem before, just curious. Matt.
Old Feb 21, 2005 | 10:40 AM
broncr's Avatar
broncr
Not in mine...
Old Feb 22, 2005 | 12:01 AM
stractor's Avatar
stractor
I have not read the post at fordsix as I am not a member , so I am assuming "walking" means in and out or end play. If so, there are several reasons this can happen. If this is a new cam installation some one could have forgotten to put the spacer between the cam and the thrust plate or the cam gear was not pushed on all the way. If using the bolt and washer method to install the cam gear , the gear will stop when it hits the washer. The cam nose will be flush with the gear hub. This is not far enough, the cam gear needs to be pushed farther until it stops , about 1/16 more. If this was not a new install, the thrust plate could be worn or broken, allowing the cam to walk back and forth.
stractor
Old Feb 22, 2005 | 04:44 PM
mattri's Avatar
mattri
Actually, the post is about the crank walking. My computer at home is acting up so it will be a while untill I can post again, Matt.
Old Feb 22, 2005 | 07:08 PM
1968f100's Avatar
1968f100
how would you ever know if your cam is "walking"?????????
F 250 6 liter
Nov 15, 2010 08:42 PM
bowhunter1331
Nov 29, 2007 03:13 PM
turboman24
Aug 13, 2007 12:28 AM
Beast12
General Automotive Discussion
59
Mar 30, 2005 09:31 PM
Matt66
Mar 14, 2005 06:45 PM
