4wd use
Old Feb 20, 2005 | 11:36 PM
jcab's Avatar
jcab
4wd use
Just a simple question, I never use 4wd in my truck and was wondering if I need to engage the gears in it to lubricate them. And if I should, how long running in 4 high and low. I live in Phoenix so not much of a need for it here. Any thoughts would be appreciated. Jeff
Old Feb 21, 2005 | 12:17 AM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
You do not have to engage the 4x4 at all. You should manually lock the front hubs once every couple of months for 10-20 miles to keep the front axle lubed up.
If you can not manually lock the hubs, just put it in 4 hi for a few miles, but try not to make any sharp turns if you are on dry pavement.
