Sponsored by: Real Truck
Stupid question
Old Feb 20, 2005 | 07:51 PM
PrarieOyster's Avatar
PrarieOyster
Stupid question
How do you shut off the auto dome lamp? I lock my truck at night and I gotta look at my truck for 20 seconds to make sure I didn't manually turn on the dome lamp. I want thing to shut off when I shut my door. I figured That I have watched mt truck for 2 hours and 22 miniutes since I have owned it waiting for that light to shut off. ( its an '04 xl 350 4x4 sc)
thanks
Old Feb 20, 2005 | 08:18 PM
Slipperyrock's Avatar
Slipperyrock
On my 05 the center of the light comes on when the door is opened. If you turn on a map light just the outer portion of the light comes on (seperate lights under the same cover). Doesn't really answer your question but will cut down on your time waiting for the light to go out.
Old Feb 21, 2005 | 01:45 AM
jackofalltrades's Avatar
jackofalltrades
Doesn't really matter if you left the dome light switch on or not. We're in the age of computer'ized trucks. Even if you did leave the light on, it will turn off in about ten minutes. (try it) There may be a way to disable it, through some of the key switch procedures, similar to turning off the seat belt warning bell that's in the manual, I dunno. But rest assured, the new rigs are designed with us dummies in mind.. (No offense intended, I'm in that group.)
Old Feb 21, 2005 | 03:34 AM
Monsta's Avatar
Monsta
Sit. Stay.
Originally Posted by PrarieOyster
I figured That I have watched mt truck for 2 hours and 22 minutes since I have owned it waiting for that light to shut off.
Did they shut off everytime you watched it??
Usually after 2 hours and 22 minutes of watching something do the same thing with the same results you can safely assume that it will do it every time.
Old Feb 21, 2005 | 04:22 AM
James Hewett's Avatar
James Hewett
Try removing the bulb, when was the last time you actually needed the bedlight? I never use mine. my neighbor always tells me I left it on, just because I leave the door open a little,I'm not a door slammer, so I took the bulb out.
They don't draw much juice and wouldn't hurt you battery.
Old Feb 21, 2005 | 09:46 AM
mwpierson's Avatar
mwpierson
It's part of the Autolamp System. In my manual it's on page 56. Look in the index under Lamps.
Following those steps the delay can be adjusted up to 3 minutes. I'm guessing that if you turn off the lights (step 5) immediately after they turn on (step 4), the delay would be 1 or 2 seconds instead of the default 20 seconds.
Maybe you could disable it if you turn the light swithch to OFF before getting out rather then leaving in AUTO.
Mike
Old Feb 21, 2005 | 12:37 PM
02superstroker's Avatar
02superstroker
mine go off as soon as I click the lock button on the remote deal...
... as long as your doors are locked why worry about it? Its going to go off one way or another.
Old Feb 21, 2005 | 01:09 PM
iskybantilus's Avatar
iskybantilus
not the headlamps, he means the interior lamps. I have an xl without the auto headlamps or whatever, and it does the same thing. its a courtesy thing so after you get out of your truck its not dark? I guess? It annoys me as well, same thing with my 04 ... i just stopped worrying about it after i realized they turn off even if you leave the door open.
Old Feb 21, 2005 | 01:14 PM
mwpierson's Avatar
mwpierson
Ooops... You're right. Sorry bout that. Disregard.
Mike
Old Feb 21, 2005 | 02:44 PM
ridered29's Avatar
ridered29
I'm sure you have the remote entry to lock and unlock- Just lock it and they go out as superstroker said his does. The light staying on bothers me too. We all know it's going to go out but, the one time you go and turn the key and nothing happens you will doubt yourself from then on !
