DWEELER, do you recall if your vibration was torque sensitive (happened mainly when accelerating) or did it vibrate under all conditions at certain speeds (foot on or off gas, coasting, trans in neutral etc.)?
Yes, my vibration was definitely torque sensitive. And it was only under light acceleration. The vibration was from 40 to 60 mph with the worst of it at 58. If I accelerated hard up through 60 I didn't feel it, but if I came up slow or drove steadily at that speed, the vibe would rattle the change in my ashtray and you could feel it in the floor, seat, center console, and steering wheel. As for coasting with trans in neutral or in gear, there was no vibe.
I drove it to the golf course today along a road that I used to really feel the vibe and I'm happy to say I'm still vibe free from the latest fix!
Anyway best of luck to you. I feel all of your pain!
The driveshaft did not fix my problem, ford has a serious problem with some of the 04 05 150's My dealer agreed and bought mine back. since they were good to work with I then decided to buy a F250 PSD and love this truck. dont let them run over you tell them to fix it or give you your money back!!
Let's see, steering wheel shimmy and vibration. Took truck in, they machined the rotors. That lasted about 1200 miles. Took the truck in again, still had vibration and steering wheel shake was back. This time they replaced rotors with the new "magic" batch of rotors. Put truck on high speed balancer, could not Road Force balance tires. Tech said that was source of vibration. They replaced all four tires. 5500 miles later steering wheel shimmy back, really bad......yesterday just got the truck back with the third set of front rotors now installed!!!!!I hope Ford has alot of these great new rotors in stock.
Vibration never went away, driveshaft replacement is sure looking good though.
Well, they have already replaced the driveshaft on my f150 Lariat. It didn't work. I took it BACK in to get the rear gears replaced on Monday 2-21-05. . . still no truck. The service manager says that now they are rebuilding the transmission!!! I just got my payment bill today- - -I'm not sure what to do with it. They obviously have no clue on what is wrong. I don't either.
teecee3
In spite of a new driveshaft, rings and pinion, body mount kit, frame dampener, two new tires, I'm sorry to say I'm still vibrating. I am told the "buzz" is "to be considered a normal characteristic of the truck at this time." Also, yesterday Ford headquarters extended the tire warranty coverage for "tire vibration, ride harshness and uneven or rapid tire wear" to 36,000 miles rather than 12,000. I'm so disappointed to say the least... Dan Stiles
Two swaps each for me(04 screw) didn't do it for me,lemon will
I'm having the same problems with my truck and my dealer. They seem perfectly content to continue to replace parts and keep my new truck in the shop. What would scare them into offering a new truck with no vibration?? teecee3
