1978 - 1996 Big Bronco
Grinding Front End
Old Feb 20, 2005 | 05:07 PM
LostNOz's Avatar
LostNOz
Exclamation Grinding Front End
Any Helpful answers would be greatly appreciated.
I have a 89 Ford Bronco, 4X4, 5.8 L ( 351 ). While driving down the road it sometimes has a grinding sound in the front end. At first I thought it was the bearings going out in one of the wheels but it does not occur all the time. I lifted the front end and checked to see if there was any tire play up and down, there wasn't. Spinning the tires also didn't produce the noise again. It does not occur when applying the brakes, or at least the noise doesn't increase. It does not occur all the time. At times it is very loud.
Again any help and your time would be greatly appreciated.
Old Feb 20, 2005 | 05:12 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
torquemeister
Dec 8, 2018 06:53 PM
jdong79
May 9, 2016 11:06 PM
MrTshirt
May 4, 2016 03:22 PM
303powerstroke
Jan 1, 2016 04:55 PM
Fedds3.0
1997 - 2003 F150
Apr 19, 2011 08:41 AM
