E-250 Rear end noise only when turning
Old 05-03-2016, 12:42 PM
MrTshirt's Avatar
MrTshirt
MrTshirt is offline
Hello All!
My van's particulars:
2011 E-250 w/4.6 L V8
65000 miles
My problem: there is an intermittent scraping noise coming from the rear wheel/axle/diff. area. this ONLY occurs when I am coasting or braking while turning right.
I does not happen when turning left, or accelerating or above ~30mph (at least I can't hear it over the normal rattle and hum)
Any advice help is greatly appreciated!
Thanx in advance!
-Tony
Old 05-03-2016, 10:38 PM
Tom's Avatar
Tom
Tom is offline
Scraping noise...almost sounds brake related. Have you taken a look at the rear brakes?
Old 05-04-2016, 09:29 AM
jimandnena's Avatar
jimandnena
jimandnena is offline
Is this a limited slip axle?
Sit in the back and have someone drive in circles in a parking lot. I had a Positrac lock up the clutches when a dealer forgot the friction additive. Caused the outside tire to drag/skip on tight turns. It leaves a faint skid mark.
Does the axle have oil?
Old 05-04-2016, 09:45 AM
delgriffith's Avatar
delgriffith
delgriffith is offline
Busted caliper pins would be my vote.
Old 05-04-2016, 11:37 AM
MrTshirt's Avatar
MrTshirt
MrTshirt is offline
when I first had my mechanic try to fix it he replaced the caliper on the RR wheel
How do I tell if it is a limited slip differential?
On the door post sticker it has 22 under axle if that means anything.
some others have suggested the axle bearing, carrier bearing and excessive axle lateral play on the axle.
the friction reducer has also been suggested by several people.
Thx again all!
Old 05-04-2016, 02:13 PM
jimandnena's Avatar
jimandnena
Thx again all!
Not limited slip according to Ford:
Old 05-04-2016, 03:22 PM
delgriffith
Also might check the front caliper pins. Sometimes sound origin can be deceiving. If you grab the caliper and lift up / pull down you might find one or more broken caliper pins that way.
With that low of mileage, seems unlikely that you've got a rear wheel bearing or rear end issue. Not impossible, but just not the first thing that comes to mind. Rear wheel bearings usually are a low rumble sound and wouldn't be linked to whether you are coasting or on the brakes.
8vettes
1978 - 1996 Big Bronco
08-06-2019 02:37 PM
mrpotatohead
04-01-2019 10:56 AM
TK 146
1997 - 2003 F150
03-11-2010 08:56 PM
punisherfx4
1997 - 2003 F150
10-21-2004 02:38 PM
winchcable
1997 - 2003 F150
04-16-2003 07:02 PM
Quick Reply: E-250 Rear end noise only when turning
