84 motor into 87
I'm putting the 300 out of my (running) '84 F-150 into the chassis of my '87 F-150 that was originally equipped with a 302. The reason for doing this is that the 87 looks like a new truck compared to the 84 and it also is an extended cab truck. The EFI components are gone as far as anything that goes on the motor, and I don't want to go through the hassle and expense of finding replacements for an injection system that is probably inferior to anything available today. That being said, I'm going to rob everything I need off of the 84 and junk the truck. Now, I've spent about 2 hours looking over efi to carb topics on the site and this is what I assume I need to do :
1) Swap out fuel tanks, or take the pump off and be creative,
2) Run my current distr/coil/module and wire it in with the 87 harness -or- buy a stand alone distr/ignition box,
3) Current alternator should work with 87 (?)
4) Nothin with the trans because it will be manual
Is there ANYTHING else you guys can think of, or correct me on??? I appreciate the feedback.....
Frank
If you're really set on going carb, by all means, feel free, however I don't see any obvious advantages. Carbs require a choke (manual or electric), don't usually get as good as mileage as EFI systems (generally, there are exceptions), stuff like that.
I personally believe and plug-and-play junkyard harness is less work than dropping two tanks and changing all that stuff around. But that's me.
Why change tanks/pumps rather than install a carb level pressure regulator in place of the high pressure fuel pump the 87 would have?
As far as advantages, I definitely agree. I mess with both systems just about every day, and EFI IS the way to go. I think in the future I might look into doing a stand alone/programmable injection system.
I was also wondering about doing the regulator thing. Is the high pressure pump in the tank and a low pressure on the frame or something?
Frank
Sure wishing you an hassle free transplant there!
Popa Tim
