Blinking ABS light
Old Feb 20, 2005 | 02:53 PM
kstrike's Avatar
kstrike
Blinking ABS light
Kind of strange. 95 Ford F-150, was towing a trailer and the ABS light began blinking, not constantly on, but blinking. Got home, and the next time I tried to start the truck, I was able to get it started, but now couldn't shift from park to drive. I now have to start the truck in neutral, and then shift to drive to get it to work. Checked the RBS II code and it showed 16 - "system operating correctly", although the Haynes manual said that the blinking light indicates loss of memory within the module - I assume that this means the module is bad, but why in the world, would the truck not now shift into drive from starting it in park? any ideas would be helpful. Thanks
Old Feb 20, 2005 | 03:17 PM
Popa Tim's Avatar
Popa Tim
Check your fuses. Check for bad ground on the interlock and nuetral safety switch.
IF you pull the interlock fuse will it shift out of park now?
Old Feb 20, 2005 | 08:33 PM
kstrike's Avatar
kstrike
Thanks for the idea. It worked like a charm. I'm still uncertain as to why a fuse for the ABS would lock the shifter in place, but a new fuse has fixed both the problems. I appreciate your insight.
