Water Pump
Old Feb 20, 2005 | 11:39 AM
KillerF250's Avatar
KillerF250
Water Pump
Hey all,
I've got a 1994 F-250 and I need to change the water pump, any special tools or tricks or is it pretty straight forward.
Thanks
Old Feb 20, 2005 | 01:43 PM
RawPower's Avatar
RawPower
If you want to take the fan off first, then you need a special wrench, but I just took mine off w/ the radiator fan still on it. You will just need to watch ou for the radiator.
There are 14 bolts (at least on mine) that are 12mm I think, and arent torqued very tight. The pump & housing arent light, so just dont let them fall into the rad.
Old Feb 20, 2005 | 03:11 PM
pnose's Avatar
pnose
The big nut that holds the fan on is reverse tread.When you remove the bolts from the water pump take notice as to where you removed them from,as they are different lengths.
Old Feb 20, 2005 | 05:24 PM
redneckf350's Avatar
redneckf350
nothing to it just put one on mine about a month a go make sure you keep the top 2 bolts seperate there shorter than the rest so they don't hit the gear that drives your injection pump. I used a chain wrench pair of vise grips to hold the pulley and big pair of channel locks to take the fan off. only took about an hour.
Old Feb 20, 2005 | 07:49 PM
rancherman84's Avatar
rancherman84
isnt there four short bolts?and the shorter bolts use a thread sealer.
Old Feb 20, 2005 | 08:31 PM
redneckf350
The company I used to work for had these motors in all there trucks and the top 2 are the only ones to worry about. we never used in thread sealer. just use the gasket and rtv sealer
