Sponsored by: Kumho
steering stabilizer?
Old Feb 20, 2005 | 07:26 AM
hillbilly316's Avatar
hillbilly316
i am lifting my 96 f-150 6" and was wondering how much difference is made by going dual stabilizer versus single
I am not going to do a ton of offroading so what would be my best option. I'm trying to save where i can
Old Feb 20, 2005 | 02:56 PM
RawPower's Avatar
RawPower
Single. If you dont off road hard then you may not even need one. I would personally still get one, but its your choice. Two is for teh rougha nd abusive (me) and can mask steering problems until they get bad.
One is all you will need, especially since you will be running under 37" tires and its a lighter truck.
Old Feb 20, 2005 | 06:02 PM
hillbilly316
ok thanks for the info. also what about sway bar drop brackets do i need those
Old Feb 20, 2005 | 09:58 PM
RawPower's Avatar
RawPower
If you would like to keep your sway bar, then yes. The easiest way (especially if you can weld) is to just get the extensions that you cut your current anti-swaybar links in half and then weld in the new 6" segments. Or, you could just go to a metal supply and buy some form of round bar of the same diameter or tubing with an inside diameter the same as the anti-swaybar links outsid diameter and do the same, but this way it will overlap.
I will be lifting mine 8" and will not have either front or rear anti-sway bars on the truck. I, however, unlike you, have leaves up front. Leaves pretty much eliminate sway anyways, as they arent the most flexable of objects. For your front coils, you may want to keep them.
My friend in his Bko doesnt run either of them and he has some body roll, mainly when he turns fast (thats become more frequent since he dropped his 351W into it).
Old Feb 20, 2005 | 10:20 PM
hillbilly316
i think i will probably just buy the brackets because i dont want to risk having too much body roll. i know i will probably have some but i would like to keep it down as much as possible
Old Feb 21, 2005 | 10:15 AM
RawPower's Avatar
RawPower
Yeah, with coils up front I would too. In rear, get them if you want them, but I would not. Leaves cannot roll enough to matter (usually). Actually I kinda take that bake, I dont know exactly on 1/2 tons, but 3/4 and 1 tons will not have bad body roll at all...
Edit: I misspelled flexible in my previous post...
KsHighboy
Nov 21, 2016 07:36 PM
Brian 2002
Apr 12, 2007 01:20 PM
whododat
Aug 14, 2006 04:26 PM
Kenworth
Feb 22, 2006 01:39 AM
fins2wheels
Oct 2, 2003 12:03 AM
