302 surging during kickdown & erratic idle
Old Feb 19, 2005 | 10:30 PM
handsofpower's Avatar
handsofpower
I have a 1986 F-150 with a 302 EFI. The engine appears to have a erratic idle when cold. The engine will bounce around from 450-700rpm and sometimes even sounds like it is about to die. The engine also starts surging whenever the kickdown is engaged at speeds upwards of 50 mph. I have new plugs, plug wires, distributor cap, and rotor button. This is my first Ford vechile to own and I'm not very knowledgable of them. Any information on how to correct these two problems will be greatly appreciated.
Thank you for your assistance,
Joel
Old Feb 20, 2005 | 07:13 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome Joel, to Ford Truck Enthusiasts! If you have a minute check out the Guidelines, it will help you to navigate through and understand FTE.
Stick around someone will be by shortly to answer your question.
We are pleased you have chosen the best source for Fords!
Enjoy FTE
…..See you on the boards.
Old Feb 23, 2005 | 01:32 AM
bigblockford460's Avatar
bigblockford460
Joel, try taking a can of carb. cleaner and mist it around your intake runners if the motor surges then try replacing your intake gaskets. I am not sure but the iac could also be at fault, which sometimes you can clean them out with that carb cleaner, but the condition you are describing to me sounds like a leak on your intake. hope this helps you own the best made truck now enjoy.
bill
Old Feb 23, 2005 | 01:34 AM
bigblockford460
also have a fire extinquisher on hand just in case your arcing somewhere because carb cleaner is very flammable.
good luck
bill
mavman427
Jun 1, 2017 09:06 AM
chertel4
Feb 27, 2017 09:48 PM
goopysteve
13
Apr 19, 2016 03:01 PM
schoo
Apr 2, 2016 09:59 AM
Polkat
Mar 21, 2004 08:01 PM
