Gas smell
Old Feb 19, 2005 | 06:40 PM
Texan58's Avatar
Texan58
Gas smell
well, you guys solved my gas tank overflow problem, so I will bother you with another one!
my 93 F-150 5.0 on start up, smells of unburned gas...very rich...
what is it?
Old Feb 19, 2005 | 08:03 PM
tex94F250's Avatar
tex94F250
Just on start up? Once it warms up is it okay?
Old Feb 20, 2005 | 08:18 PM
Texan58's Avatar
Texan58
yes sir, that is correct
Old Feb 21, 2005 | 04:21 AM
tex94F250's Avatar
tex94F250
Check and clean the IAC (idle air control). See if that improves the situation.
Old Feb 21, 2005 | 07:36 AM
holland501's Avatar
holland501
Considering the age of your truck, you may have a cracked hose or a bed seal somewhere. B4 you start the truck some morning, lift the hood and look around. Take a good wiff for gas fumes. If you don't smell anything, have someone turn the key to the run position. This will pressurise the fuel system. Now sniff. When everything is cold, old/cracked lines will tend to leak. When things get heated up, the leaks can sealup. Good luck.
Old Feb 23, 2005 | 07:15 AM
Texan58's Avatar
Texan58
Thanks guys, I will do both. If it was a really old truck, where I could replace points, check timing, etc., thats the first thing I'd do. Smells like bad air/fuel mixture
Old Feb 23, 2005 | 03:08 PM
chrono4's Avatar
chrono4
what temp themostat do you have in it? it might not be heating up fast enough so the comp could be dumping fuel for heat up. just a thought
Old Mar 29, 2005 | 04:22 PM
jmonte1's Avatar
jmonte1
fuel injectors leak?
i too have a gas smell...my question is - can it be a leak from one of the fuel injectors?
1989 f150 300/straight6
Old Mar 29, 2005 | 05:46 PM
tex94F250's Avatar
tex94F250
Just out of curiosity, check the vacuum line to the fuel pressure regualtor for the presence of gas. If it has a regulator going bad it would be present and the diaphragm may equalize and maintain pressure once it's run awhile. Just a shot in the dark, by the way.
