fog lights
Old Feb 19, 2005 | 05:22 PM
BUSTER05's Avatar
BUSTER05
fog lights
hi fellas i just got put some new fog lights in my truck. i ran the hot wire with the low dim lights that way when i turned on my brights my fogs would turn off. now neither my low or my fogs work and there is no wires cut. is there some kinda of fuse or something that maybe could have blown. im out of ideas. thanks
Old Feb 19, 2005 | 07:49 PM
Franklin2's Avatar
Franklin2
Could be a fuse. Depends on what year truck you have. If you ever figure it out, you need to add a relay in there like this.
Old Feb 20, 2005 | 08:48 AM
BUSTER05's Avatar
BUSTER05
fogs
i have a 97 f150 i thought that if i ran into the low beams that i wouldnt need a switch but i guess i was wrong. thanks alot
Old Feb 20, 2005 | 08:06 PM
MemOrex's Avatar
MemOrex
You don't need a switch. All you need is to install a Relay so the fog lights don't overload that circuit and blow the fuse.
05 f250 6 inch lift
Jun 29, 2016 07:40 PM
jman228
Apr 10, 2015 08:44 AM
kschroeder.DVM
Jun 22, 2014 10:57 PM
snowdog79
Electrical Systems/Wiring
Mar 19, 2011 12:26 AM
