1978 - 1996 Big Bronco
Tailgate window seal
Old Feb 19, 2005 | 03:39 PM
96Broncowner's Avatar
96Broncowner
Whenever I go through a carwash or it rains, the carpet in the cargo area towards the back is wet. I have noticed that in a carwash some water comes in through the very corners where the glass meets the tailgate. Has anyone ever replaced the rubber gaskets and if so can you point me to a place to find them? Thanks
Old Feb 19, 2005 | 05:45 PM
tex94F250's Avatar
tex94F250
Arrow Leaking tailgate seal
I never had that problem with my '96. If it were older, I'd suggest LMC or J.C. Whitney. Ford will still support the '96 and you may be able to order seals there. I'd float this on BigBroncos.com and see what you get. Are you certain that your tailgate is fully latched? I did have one instance where I didn't have the lugs fully latched and had the window up. Leaked right at the glass/tailgate juncture on each side. To repair, closed tailgate tightly. No recurrence.
Old Feb 19, 2005 | 06:12 PM
MinnManBroncoFan's Avatar
MinnManBroncoFan
http://broncograveyard.com/products/cat/20/82
Old Feb 19, 2005 | 09:22 PM
96Broncowner
Thanks MinnManBroncoFan. I ordered some weatherstripping ends from the site. I will keep you posted if they do the trick. Great site for parts, thanks for the tip.
Old Feb 20, 2005 | 03:22 PM
rksiewert's Avatar
rksiewert
Had the same problem on my 95, got the ends and the whole stip fom Jeffs, and took care of the proble.
RAy
Old Feb 20, 2005 | 11:13 PM
RRobben's Avatar
RRobben
Did mine about 2 months ago. Got all of the parts (end caps, inside and outside belts) from the Broncograveyard. Took all of about 30 minutes. Not only does it not leak anymore, it also looks better too!
Old Feb 21, 2005 | 10:54 PM
BroncoBill's Avatar
BroncoBill
Smile Rear Window Gaskets
I own an "82 Bronco, which I am very fond of. I bought it a few years ago, really cheap. This past summer I replaced the exterior rubber, including tailgate window gasket. I bought it from JCWhitney it was very cheap, and very easy to install. Hope this helps and good luck.
willowbilly3
1997 - 2003 F150
Jan 25, 2017 11:53 AM
Watcher58
May 13, 2016 03:29 PM
sgtrwt
Jul 13, 2015 05:13 PM
Buck 1
2009 - 2014 F150
May 10, 2015 11:27 AM
Yougotthehit
Apr 6, 2009 09:46 PM
