efi 302
Old Sep 5, 2001 | 11:36 AM
ronc48's Avatar
ronc48
efi 302
HELP, i brought a 1985 f-150 with a efI 302 for $125.00. the kid i got it from knows nothing about motors and had been messing with it and srewed it ( wires and plugs) up. I can't seem to find anyone that knows what PLUGS go in the motor. Everyone ( including FORD DEALERS) keeps telling me that it takes the asf32c which it doesn't (not long enough) I've told everyone that it takes a extented plug and they all say that someone has messed with the heads. I don't belive that no one is that dumb to change that. it had to be done at FORD when truck was made. Does anyone know what PLUG it takes. thank you.e-mail me please at ronaldc22 at excite.com thanks again
Old Sep 5, 2001 | 10:27 PM
ecarter50's Avatar
ecarter50
efi 302
Maybe someone has changed the motor or heads to a 75 or older which uses larger plugs. Wouldn't the easiest way to get a plug that fits be to remove one you have and take it to a parts store.
Old Sep 6, 2001 | 12:20 AM
AWGuinn's Avatar
AWGuinn
efi 302
My question is how do you know the asf32c is not long enough? Maybe someone got the wrong plugs in the past for it. If you've pulled the heads and know for sure you need a longer plug, then by all means take the old one in and get some replacements. In my experience, motorcraft runs the best in Ford engines. Let us know how it turns out.
Old Sep 15, 2001 | 10:04 PM
ronc48's Avatar
ronc48
efi 302
Your right, but like i said the kid I bought it from had screwed with it and it didn't have any plugs in it
Old Sep 15, 2001 | 10:57 PM
fourtrax's Avatar
fourtrax
efi 302
there are some casting numbers on the head you should be able to cross-reference them and idenitfy the year. try searching for something like ford head cast number this is one of the sites i found and it seems to have a goot bit of info. Good luck FourtraX
http://www.actionsalvage.com/cylheadsford.asp
Old Dec 23, 2001 | 09:41 PM
buckford's Avatar
buckford
efi 302
in my 86 efi the plug is champion 403
Old Dec 27, 2001 | 10:41 PM
model t's Avatar
model t
Post efi 302
My 86 F-150 EFI has a Bosch 7586 in it.
Old Dec 28, 2001 | 04:36 PM
knuckles's Avatar
knuckles
efi 302
Highriser4
1978 - 1996 Big Bronco
Jan 4, 2013 09:02 AM
86--F250
34
Jun 28, 2012 10:15 PM
jwmustangman
May 8, 2007 10:01 PM
1990Fordf150v8
38
Sep 19, 2003 08:25 PM
jonw440
Jan 13, 2002 03:56 PM
