E350 Frt Shock Replacment Tip (Old Style)
Old Feb 19, 2005 | 12:27 AM
mpsuda's Avatar
mpsuda
I have a tip for replacing the front shocks on a old style (1987) E350. The top shock mount nut is very difficult to reach. Not much room between the top shock mount and the body. I have heard people cutting a hole from the top so it can be reached or cutting the shaft off near the top to remove the shock.
The factory service manual mentions putting a wrench on the to nut and turining the shock shaft to remove the nut. Before reading this I probably would have struggled to turn the nut on the top in the confined top space. Below the rubber bumper and washer the shaft is made so a 3/4 wrench can be used to turn the shaft. I think the top nut is 9/16.
I sprayed the nut down with penetrating oil and let it sit overnight. I placed a wrench on the top nut and used the body to hold it while I turned the shock shaft. It easily came loose. You need small hands to get between the shock mount and body.
The shock replacement was not as bad as it looks.
Mike
Old Feb 19, 2005 | 04:37 AM
trike1946's Avatar
trike1946
Thanks for the tip. I have a 90 E350 and just bought new front shocks. I thought about cutting a hole in the floor. But this sounds like it might work. Thanks again.
sfc2001
22
May 9, 2023 02:36 PM
Countryboy90
Oct 21, 2015 07:47 PM
AAubinoe
23
Aug 9, 2015 10:43 AM
Adirondacker
80
Apr 4, 2015 07:37 AM
blinkerf150
May 1, 2012 04:29 PM
