Sponsored by: Real Truck
Subwoofer boxes in '05 crew?
Old Feb 18, 2005 | 09:07 PM
tazmanian_cowboy's Avatar
tazmanian_cowboy
Was talking to my brother today and we were wondering if anybody has seen or built a sub box for either under the rear seat or behind it in an '05 crew cab?
Pictures are welcome!
Taz
Old Feb 18, 2005 | 11:07 PM
arcturner's Avatar
arcturner
Taz: I plagaiarized this from a previous post of mine:
Not much room for sure...I built a box and placed an 8 inch Earthquake SWS (shallow subwoofer system) inside. Used 3/4" particle board and made a box approx 22" x 4" x 9" and wrapped it in dynamat extreme and filled it with fiberfill, which fit just right underneath the one-way vents that you'll find underneath that black fibery cover in back and powered it with an Alpine MRV-F450 (200 watts to the sub alone). For me, the sound is great. It won't rumble the neighbors from sleep, but it will rumble my innards and make my pantlegs shake at times.
If you got very creative and spent some quality time with a jig saw, you might be able to make a box to fit a couple of 10's back there but I think you'll need to use shallow subwoofers (hard to find) and it will take some time.
First, take that black fibery cover off and survey the landscape. It pops off easily with 3 torx bolts and those 4 tabs up top. I had to cut quite a bit of it away to fit the sub and the amp. I think you'll find more unused space back there than that covers allows you to assume - use it wisely and who knows.
As far as aftermarket boxes specifically for that space, your choices, as of 2 months ago, were basically zero, unless you own a Harley edition. I initially spent much more time searching for the perfect box that I was willing to pay just about anything for, but it just didn't seem to exist.
My system now consists of an Alpine deck, the amp, the sub, and 4 Infinity Kappa 5x7s. No ear bleeding volume from my system but I feel like I have tremendous, distortion-free SQ at levels that leave my ears ringing when I get out. lInstalling 6x8s in an '05 F350 Crew may require a plasma cutter or some more quality time with a metal saw. And don't forget dynamat or something like it. I covered the front doors and the entire back of the truck, including the C pillars and the inside of the C pillar plastic covers and I still get more than enough resonance from the floor and roof. I'll get around to covering those at some point.
Soundtrack wanted $2800 for the same system installed. Using e-Bay and a weekend of elbow grease, I did mine for less than a thousand, complete with twisted 12 guage wire and XM radio, and I got to know the innards of my new truck pretty well. Enjoy!!
Feel free to PM me for more detail.
<!-- / message -->
Old Feb 19, 2005 | 11:54 AM
Lashlaroo's Avatar
Lashlaroo
Check out my pictures. behind the seat, under the power window sliding stuff. Sounds great.
Old Feb 19, 2005 | 06:13 PM
nhebert's Avatar
nhebert
I see the picture, what brand/size of sub woofer is that ? Did you have to tear out the tool tray ?
Old Feb 23, 2005 | 02:28 PM
OverHeight's Avatar
OverHeight
I have the 05 and want at least one sub, or possibly 2 if I can fit them. I found a company by the name of Xscorpion, they dont have a web site yet. That makes sub boxes and other stuff. They list a box for the 04 crewcab (x7985-10) that hold 2 10". I emailed them to see if it went behind or underneath the seat, the email I got back was, we don't know. That will instill a lot of confidence. Heres a link to someone that has a picture of it on their site. Very bottom picture. http://www.lightav.com/car/boxes/xscorpion/special.html
Old Feb 23, 2005 | 03:27 PM
photonv's Avatar
photonv
Wink CC Behind seat 12" sub
I had an 04 SD CC. I made my own wedge shape box. I install a Pioneer Premier YS-SW124D Low pofile 12" sub. To get the cu ft I made the box a little over half way across. I took out the tool tray. and Mounted the amps on the back wall next to the box. The speaker came with complete specs for volume. I found an online calculator somewhere to determine specs for the wedge box.
mmcd7006
Nov 18, 2012 06:59 PM
caddylt1
General Diesel Discussion
Dec 9, 2007 10:36 PM
scooterstruk
2004 - 2008 F150
Jul 5, 2007 09:32 PM
pfk1616
Mar 18, 2005 08:53 AM
Chipmm
Car/truck Buying Advice
17
Oct 5, 2004 08:43 PM
