Do you mean the pitman arm that goes on the steering box or the steering arm that goes on the spindle? What's wrong with yours? Mid Fifty has most all the front end parts.
Not the pitman arm, guys. Its the U-shaped deal that has a ball for the forward end of the draglink. The steering arm has a shaft that goes into the spindle and a lock nut that holds it. Apparently, the part has not been produced for many years.
MF lists them as used only available. There shouldn't be a shortage of them in the salvage yard. The ball is the only wear item and is replaceable. A number were bent for use on a dropped axle tho.
