99 250 overhead console
Old Feb 18, 2005 | 03:14 PM
dieselstroke's Avatar
dieselstroke
Question 99 250 overhead console
Whats the deal with this stupid overhead instrument thing. It has no
fuse? at least it doesnt show it in the owners manual I looked 3 x's
& it says nothing about a fuse for it. I pulled every fuse to check, none
were bad. It hasn't worked since I've owned it, I'm only fixing it for when
I sell the truck. Anybody know what the problem might be?
Old Feb 18, 2005 | 06:18 PM
Franklin2's Avatar
Franklin2
Give me a little rundown of what the console contains, and I will see if I can figure it out when I get access to my diagrams.
Old Feb 22, 2005 | 07:48 PM
Bmoney's Avatar
Bmoney
Did you ever get an answer on this? Can the folder admin help? I have checked all my fuses on my 2000 F250sd to find out why my overhead console went out? can't find anything.....
Old Nov 24, 2006 | 09:59 PM
cobramustangboy's Avatar
cobramustangboy
Hey, the overhead console doesn't work either on my 99 f250 lariat 4x4. There is a fuse, I believe #15 on the fuse panel under the dash. i checked that one and it wasn't blown. but there is a fuse panel under the hood, which i haven't checked, but i don't think it would cover the overhead console. If you find anymore out let me know please. thanks
Old Nov 24, 2006 | 10:13 PM
Franklin2's Avatar
Franklin2
The fuse for the overhead console is #10, in the fuse panel under the dash on the left. This powers the microprocessor that controls the compass and outside temp functions. It must also have some other calculations since the vehicle speed sensor signal goes into it too. There is a lightblue/red that comes from the dash lights for nighttime illumination, and there are two wires for the map lights.
Old Feb 16, 2008 | 11:00 AM
chad.h's Avatar
chad.h
My over head console keeps going out to, if I hit it or take it off it will stay on until I start to drive, then it goes out, any body have any Idea how to get it to stay on?
chad.H
2004 F-350 Lariet Diesel
Old Feb 18, 2008 | 09:02 AM
Franklin2's Avatar
Franklin2
Apparently Ford has had a lot of problems with the solder joint quality on the circuit boards. Here's a guy who repaired it himself.
http://www.forgotton.net/diesel/trip...ndexframe.html
Old Mar 10, 2008 | 05:37 PM
zx250's Avatar
zx250
Of the next Riffraff East
HERE is one of our members write up with pictures. It works, fixed mine 2 years ago and no problems since.
Old Mar 11, 2008 | 09:09 PM
jamrock's Avatar
jamrock
I'm about to install one on my 99f150 lariat. I checked in the headliner for the harness(unscrewed sun visors, side trims, visor clip and Door rubbers), i shoved my hand into the space and didn't feel one. Canyou tell me if there's one there or will I have to hard wire it, also installing a gentex electrochromic rear viewmirror with compass and lights. If there isn't a harness, do you think its okay to use the compass and temp sensors to also feed console.
NDrum2005
Dec 6, 2021 07:38 PM
kevinv10
Jun 21, 2014 11:58 AM
Metsfan68
Electrical Systems/Wiring
Jan 3, 2012 06:18 PM
lvm1114
Aug 17, 2006 08:49 PM
lvm1114
Jul 23, 2006 03:10 PM
