66 master clyinder
Old Feb 19, 2005 | 07:43 PM
banjopicker66's Avatar
banjopicker66
Yep, that is certainly understandable!
I would reiterate to compare your old master cylinder with the '72 2x4 and the '72 4x4 with 4 wheel drum brakes.
I had to replace the master cylinder on my son's '72 2x4 with 4 wheel drums. They gave me one but the pushrod was too short.
Turns out the first one they gave me was for a '72 4x4 with 4 wheel drum brakes.
The correct one was longer.
It didn't occur to me until a few days later that the 4x4 one might be just right for our Slicks!
That's why I am suggesting you compare them. If the 4x4 is correct for pushrod length, then you solve a BIG issue with this upgrade. Less work for you to do.
Get a proportioning valve from a 4 drum truck and you will have the key components. The only other issue will be the brake light switch. Search here for options to overcome that.
Good luck and keep us posted!
pmetro1
Electrical Systems/Wiring
Jan 29, 2024 06:52 PM
hoss73ford
32
Aug 22, 2019 01:26 PM
66Warhorse
Nov 29, 2016 09:04 PM
f250custom78
1966 - 1977 Early Broncos
Jan 18, 2016 04:50 PM
libertyky
Jul 7, 2015 05:12 PM
