460 timing??
Old Feb 18, 2005 | 11:01 AM
75fordkid's Avatar
75fordkid
Smile 460 timing??
Hey guys. Im havin trouble getting my 460 timed rite. Its set at 12 btc, and its still runnin like @#$@. Should i pull the vacume hose off the dizzy and set the timing again. Im kind of lost and not really sure what to do?????? Thanks Guys Matt
Old Feb 18, 2005 | 03:37 PM
BigRed350's Avatar
BigRed350
Matt, whenever you set the initial (lead) timing, always do so with the vacuum advance hose pulled off and PLUGGED. The reason you want to disconnect and plug it is so there is no chance of the vacuum advance "coming in" and affecting your settings. The reason for plugging the hose is to prevent a vacuum leak otherwise which would raise your idle speed and possibly cause your mechanical advance to kick in. Make sure your idle is under 900 RPM or the mechanical advance could come into play.
You say it runs like #@&%#$. What are the symptoms? Does it detonate upon acceleration? Does it run rough?
Mark
Old Feb 20, 2005 | 12:39 AM
460f250's Avatar
460f250
You sure the distributor is in right, and not out one tooth?
Old Feb 20, 2005 | 02:12 PM
doccamel's Avatar
doccamel
One thing, go back to basics to rule out the simple things. Wires in the right order, plugs good, comp. good. cap and rotor in good shape, coil is giving good hot spark. Prob you have already done this but worth a mention.
Old Feb 21, 2005 | 11:00 PM
79F350429's Avatar
79F350429
should there be full or ported vaccum at ditributor?
Old Feb 21, 2005 | 11:28 PM
SwOkcOffRoader's Avatar
SwOkcOffRoader
ive had my vac adv on a full vacuum port for years with out problems, but ive read different stories on FTE that made me want to switch to a ported vacuum off the upper part of the carb, from what they say it should work better because of how the vacuum reacts when you hit the throttle, if its on a full vaccum, the vacuum drops when the throttle is hit, if its on a ported line on the upper part of a carb, the vacuum rises when the throttle is hit, im gonna change to a ported line when i find a different metering block for my holley........
shanes66charger
Jan 2, 2012 10:10 PM
gthbryce
Jul 7, 2009 09:48 AM
billg302
70
Dec 30, 2008 02:12 PM
Big_MARK
Sep 1, 2008 09:56 PM
75fordkid
46
Feb 27, 2006 07:54 PM
