Sponsored by: Auxito
po455 code evap
Old Feb 17, 2005 | 08:52 PM
jstang95's Avatar
jstang95
po455 code evap
hi new here first time to post got this code when i scanned the truck checked the hoses and elbows all around the canister didnt hear any leaks or see any wanting to know if there is a better way to check for the leaks other than just listening and also can the canister itself just quit working can this also trip a po171 code thanks
Old Feb 18, 2005 | 06:39 AM
projectSHO89's Avatar
projectSHO89
P0455 Gross Evap Leak most commonly occurs because the gas cap is not installed correctly.
The P0171 is possibly related if there is a major leak in the purge line to the CV solenoid.
A fault in that section could explain both codes.
Steve
Old Feb 21, 2005 | 06:16 PM
jstang95's Avatar
jstang95
checked the gas cap it seems to be ok how do i check the purge valve to see if it is working
Old Feb 21, 2005 | 06:44 PM
jstang95's Avatar
jstang95
i checked the gas cap and around the filler neck like where the fuel pump hits it is chiped would thatcause it to trip this code
Old Feb 21, 2005 | 09:24 PM
Racerguy's Avatar
Racerguy
That could cause it if the outer lip of the filler is chipped where the cap seals.
A more common problem for a P0455 is a bad Canister Vent Solenoid or the wiring to it.
If you do a search in here I think you'll find a few posts about it.
tseekins
Apr 7, 2015 02:30 PM
RickS1986
Sep 28, 2014 04:16 PM
Stockdale Dave
Aug 29, 2012 08:04 PM
elrodalonzo
Oct 20, 2009 05:36 PM
302VAN
Apr 27, 2008 08:21 PM
