Squeaky Squeaky squeeeeeeeeeeeee...
Old Feb 17, 2005 | 01:08 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
1994 F-150 5.8
That's what it sounds like from a dead stop. It repeats squeakiness until about 23 mph, then it's a soft whine. It's definately coming from my rear end. I can't tell what it is, and it's scary, cause it's not something I can afford to fix. it is not rpm variable. It sticks with the speed of the truck. Anyone have a clue? Thanks.
Ryan
Old Feb 17, 2005 | 01:24 PM
XuPiTeR's Avatar
XuPiTeR
When was the last time you changed your pads back their?
Old Feb 17, 2005 | 04:17 PM
FghtinIrshNvrDie
not a brake problem. it's not as bad when I slow down. When I accelerate I get that sound. It's slightly apparent on the slow down. Ryan
Old Feb 17, 2005 | 04:39 PM
300 4 ever's Avatar
300 4 ever
"not variable by rpms"-what about speed? It could be the universal joint. Buddy of mine had that problem with his chebby. He drove it by my, trying to vary the speed, and it was speed related. He took it in and it was the universal joint. Hope this helps.
Old Feb 17, 2005 | 05:15 PM
77_F150_4x4's Avatar
77_F150_4x4
Well do you have any vibration? if its sqeaking its something thats moving crawl under it and look at your ujoints? is it a long bed or x-cab? do you have a carrier bearing that will squeak and vibrate. When was the last time you checked or changed the rear end fluid? Check all the moving parts out diagnos from there.
Curtis
Old Feb 18, 2005 | 01:10 PM
FghtinIrshNvrDie
it's a standard cab long bed. I had to replace the speed sensor a while ago... I may have lost some fluid from the differential. When I said it's not variable to rpm's, I meant that it does increase in quickness with speed until it gets fast enough to sound like a soft whine.
I also had a question about how to check the fluid level inside of the diffential. How's that done? I'm assuming there's a special kind of fluid I've never noticed before.
Ryan
Old Feb 18, 2005 | 02:05 PM
qman's Avatar
qman
There's a threaded plug in the front of the differential. You stick a 3/8 ratchet into it and unscrew it. You check it by filling it with the proper gear/limited slip oil mix until it reaches the level of the plug hole and starts pouring back out. That's when you have the right amount in there.
Old Feb 18, 2005 | 07:17 PM
MemOrex's Avatar
MemOrex
Spray your U-Joints with some WD-40. If the squeaking goes away, you found the problem.
Old Feb 18, 2005 | 11:56 PM
88n94's Avatar
88n94
If it's a 4X2 and you do in fact have a carrier bearing, as 77_F150_4x4 called it(or hanger bearing, whatever the official name for it is) that sounds like the most logical culprit.
