exhaust system
Old Feb 16, 2005 | 10:08 PM
snagmaster86's Avatar
snagmaster86
exhaust system
I was just looking to get an dual exhaust system put on my truck. It's a 79 f-250 with a long bed. What size pipe would be the best to use? Are there any kits available that I can bolt on myself? Anyone from PA know how much I can expect to pay for a custom pipe job?
by the way, the motor is a 351m
Old Feb 16, 2005 | 10:10 PM
Mil1ion's Avatar
Mil1ion
This would be better asked in the Exhaust forum.
I would suggest not more than 1 3/4" pipe.
Old Feb 17, 2005 | 08:55 AM
77f2504by4's Avatar
77f2504by4
1 3/4 is waaaaaaaay to small. go with 2 1/2. thats what all of my trucks have. or 3 inch.
Old Feb 17, 2005 | 09:03 AM
amish77's Avatar
amish77
yeah a v-8 (especially a 351C or bigger) needs more like a three inch. You could probably do fine with a 2.5 for the small blocks, (302 and 351W) but for a bigger motor, or one that you are looking to hot rod, you may want to consider the full three inches.
EDIT:
oh, but in light of the administrator comment, 1&3/4 willbe closer to stock and allow the motor to be a bit more quiet. The only problem with the quietness is that the motor has a little more trouble breathing, making slightley less tourque and therefore slightly less resulting horsepower. But if you don't care about the power numbers, the 1&3/4 should also be a little cheaper (less for materials, and easier to fit for less labor)
Old Feb 17, 2005 | 09:24 AM
snagmaster86
Sounds like I will be going with the 2 1/2 or 3 inch. I would like to get some extra gas mileage by putting on this system. Also, I don't want it to be a quiet truck. THanks for your help
Old Feb 17, 2005 | 09:33 AM
Red77F100's Avatar
Red77F100
I dunno jack about V8s. I DO know that LMC Truck has bolt on exhaust systems for all models of Ford trucks. Check their catalog!
73Custom's Avatar
73Custom
It all depends on the motor and what you use it for. In my opinion, there is no need for a stock motor in a daily driver to have larger than 2 1/2" dual pipes. The only time you need larger is a built high rpm motor (like runs over 5000 rpm regularly for an extended time). I think you'll be wasting you money if you go bigger than 2 1/2" duals. My stock 390 4v has long tube headers and 2 1/4 duals and I think it's perfect. But it's a daily driver that very seldom sees 4000 rpm and NEVER goes much higher than that.
My exhaust was custom bent at a exhaust shop, made from aluminized pipe (which lasts WAY longer), glass packs and exits behind the rear wheels. Cost me $200 total and took the shop less than 1 hour to install.
Marty
Old Feb 17, 2005 | 10:09 AM
jstandle's Avatar
jstandle
Marty is right, it depends what your motor is used for. Smaller tube, 2-2.25" can help efficiency of the exhaust. There is a big write up somewhere on this site explaining all the mumbo jumbo, exhaust velocity, etc.
If you have a motor built for lower end torque you're going to be better off with 2 or 2.25" exhaust. 2.5" will work but might actually get you less performance in your application. I'm no expert though. I would recommend searching to find that post.
Jordan
Old Feb 17, 2005 | 10:19 AM
Mil1ion's Avatar
Mil1ion
Having the pipe TOO BIG is a problem.
Plus, that huge 351M only puts out 140 HP.
I have 2 1/2" true duals for my 429 and pipe is too large.
You will get a real tinny sound & the engine won't have enough back pressure to keep the exhaust valves stable.
Old Feb 17, 2005 | 09:04 PM
snagmaster86
what size will get me the best gas mileage and which would most likely give me the most power?
It's a daily driver but it is also getting some performance parts(Intake, carb, maybe a cam).
Million...where did you get the HP on the engine?
Old Feb 17, 2005 | 09:41 PM
Mil1ion's Avatar
Mil1ion
I have a library with lots of info.
The 351M had about 146 HP & the 400 was about 160 hp.
You can get all this info in the 335 engine series forum
Old Feb 18, 2005 | 03:11 PM
fordfan302's Avatar
fordfan302
LMC Truck Magazine has a really nice true dual system for your truck....it comes with 2.25 inch pipes and your choice of glasspacks or turbo mufflers and its at a pretty good price $170 - $200
Old Feb 18, 2005 | 09:57 PM
kens64's Avatar
kens64
Care to explain any of that? Like how pipe size, and not muffler choice, header choice, etc. will affect sound? If anything, larger pipe will give a deeper tone, than smaller pipe.
Also, please explain how poor cylinder scavenging, poor flow, low efficiency and excess trapped heat keeps valves stable?
Not trying to be a jerk, but I would love to hear your opinion on this.
Old Feb 18, 2005 | 10:43 PM
Red77F100's Avatar
Red77F100
I don't even know what cylinder scavenging is! I'm glad I didn't say it!
Flowmaster vs Magnaflow - which is better?
Old Feb 19, 2005 | 01:46 PM
snagmaster86
I am looking at a kit from hooker. It's 2 1/4" duals. Any idea on what mufflers will get me the best performance?
