Quick trans Q??? C6 vs AOD
Old Dec 2, 2001 | 01:13 PM
Mil1ion's Avatar
Mil1ion
Old Jan 14, 2002 | 12:00 PM
onestep's Avatar
onestep
Are all C6s 3 speeds, and or are all AODs 3 speeds and overdrive?
Thanks for your input,
I want to change the filter and oil in my trans and I have to figure out which I have. It may still be the original '85 trans in it.
Drake
Old Jan 14, 2002 | 12:13 PM
400m's Avatar
400m
yes the C6 is a 3 speed and the AOD has overdrive thats what the OD means, If the tranny is stock then the code on the doortag should tell you. If not there should be a tag on the tranny itself that will tell you.
Old Jan 14, 2002 | 01:11 PM
onestep's Avatar
onestep
Unfortunaly the body was repainted and there is no sign of the door tag, plus there were no tags on the tranny that I could find, just a large number 64 cast into the scatter shield, just in front of the trans oil pan seal.
Thanks for your help though.
Old Jan 14, 2002 | 02:59 PM
JJ_00's Avatar
JJ_00
The oil pan on the AOD is rectangular while the pan on the C6 has a cut out in it. Hope that helps.
Josh00
Old Jan 14, 2002 | 07:05 PM
onestep's Avatar
onestep
Thanks so much guys I now know what I have.
Thanks again, I hope I can return the help some day.
Drake
Old Jan 14, 2002 | 10:54 PM
390GT's Avatar
390GT
AOD pan also says metric on it.
at least on my old one......i am canadian though.
Old Jan 15, 2002 | 05:31 AM
onestep's Avatar
onestep
I just came to an evil realization that if I were to borrow some truck parts I could start a killer drag/track mustang project car. 351 power, c6 trans, and 9" rear. All the racers standard gear!
