Sponsored by: Auxito
1997 expedition
Old Feb 16, 2005 | 04:42 PM
billysemken's Avatar
billysemken
1997 expedition
R&R Heater core; disconnected bulkhead wiring harness under hood.Going inside to bulkhead wiring connector, pulling on handle to disconnect harness,will not come disconnected. All three connecters were loose under hood. Pulled instrument on right side back far enough to bearly have room to get the core out. Why wouldn,t the connecter come loose!!! any body have this problem!!
Old Feb 17, 2005 | 12:49 AM
Racerguy's Avatar
Racerguy
Hi Billy and welcome
If I remember right there are some tabs that hold the connector to the firewall. I think you have to release them from in the engine compartment.
Old Feb 17, 2005 | 02:16 PM
billysemken
1997 expedition
T/U I toke a small L shaped flat tip screw driver and worked on them too. I just pulled out the rignt side with enough room to get top of heater box. really made it go back together easier by not coming out as far as lining up. thank you again. Billy
Old Feb 20, 2005 | 06:28 AM
97fordf150's Avatar
97fordf150
Send for the instructions, dont remove bulkhead harness.
Unnecessary labor. Hope I caught you in time.
email me for the instructions how to replace heater core on 97 F150 and Expeditions, very step by step and leaves out what the dealer mechs skip too.
Don
Old Feb 20, 2005 | 08:33 AM
billysemken
Thank you, I,m at EAUTOMOT@BELLSOUTH.NET
Don
T/U I would like to see your instructions on the Exp. I usually stay away from some work,I stay busy as it is, but it was some body that didn,t have a lot of money so I helped them out.I did pull it out for enough to get the top off,heater core came right out after the I pulled the blend door out.Billy
