Can someone verify a spec I saw in my Hayne's manual?
If someone out there has a Ford factory repair manual (or other manual), would you please look up the spec for the clearance between the rocker arm and valve stem? The clearance pertains to an all-components-installed condition and with the lifter completely compressed (i.e., with all the oil squeezed out of the lifter). Manual might state something like, "Compressed Lifter Clearance" or "Rocker Arm-to-Valve Stem Clearance."
I have a value in my Haynes manual, but I want to verify this with the spec from another manual.
Thanks,
Matt
Thanks,
Matt
Originally Posted by 95X15
95 manual: for 4.9 Collapsed Tappet Gap (Clearance) Desired - 0.125-0.175; Alowable 0.100-0.200". 5.0/5.8 Desired 0.091 - 0.151; Allowable 0.071-0.171 Lightning 5.8 is different. If you need more post back. Engine not specified above.
By the way, what manual did you use to look up these values?
Thanks,
Matt
Since you say it's the "95 manual" I guess that means the factory manual?
Thanks again,
Matt
Checked 88 ford factory manual says allowable is 0.071 - 0.193 and desired is 0.096- 0.165 for 302; hope this helps. This would probably be more correct than 1995 information since a change was made in body and probably emissions in 92.
guzzler96
