Can someone verify a spec I saw in my Hayne's manual?
Old 02-16-2005, 11:43 AM
Matt Wilson's Avatar
Matt Wilson
Matt Wilson is offline
If someone out there has a Ford factory repair manual (or other manual), would you please look up the spec for the clearance between the rocker arm and valve stem? The clearance pertains to an all-components-installed condition and with the lifter completely compressed (i.e., with all the oil squeezed out of the lifter). Manual might state something like, "Compressed Lifter Clearance" or "Rocker Arm-to-Valve Stem Clearance."
I have a value in my Haynes manual, but I want to verify this with the spec from another manual.
Thanks,
Matt
Old 02-17-2005, 08:28 AM
95X15's Avatar
95X15
95X15 is offline
95 manual: for 4.9 Collapsed Tappet Gap (Clearance) Desired - 0.125-0.175; Alowable 0.100-0.200". 5.0/5.8 Desired 0.091 - 0.151; Allowable 0.071-0.171 Lightning 5.8 is different. If you need more post back. Engine not specified above.
Old 02-17-2005, 12:11 PM
Matt Wilson
Thanks for the response! I'm sorry, but I now realize that I did forget to specify the engine and the year of the truck (man, what was I thinking? ). It's a 302 in a 1990 F150. I guess I was in such a hurry that I just blew right through that...
By the way, what manual did you use to look up these values?
Thanks,
Matt
Old 02-17-2005, 12:26 PM
Matt Wilson
Since you say it's the "95 manual" I guess that means the factory manual?
Thanks again,
Matt
Old 02-18-2005, 08:25 AM
95X15's Avatar
95X15
95X15 is offline
Checked 88 ford factory manual says allowable is 0.071 - 0.193 and desired is 0.096- 0.165 for 302; hope this helps. This would probably be more correct than 1995 information since a change was made in body and probably emissions in 92.
Old 02-18-2005, 07:56 PM
Matt Wilson
Thanks again! That definitely helps.
Matt
Old 02-20-2005, 02:25 PM
guzzler96's Avatar
guzzler96
guzzler96 is offline
Post
I have the truck shop manual for a '90 that I bought when I bought the truck and the info above is shown just as stated.
guzzler96
